More polybushes :D
s3clarke
Money grabbing s3!
Bromsgrove
Decided to give the bottom arms a blast, I used a drill and a gas gun for fire to get the rubbers out, then a hacksaw along with a chisel to get the collars out. after getting a wire brush in the holes to clean them up, I then used grease, a vice, a bolt with washers and a hammer to get the bushes back in. to be honest, all in all it took me 3 hours, and it wasn't a crappy job either.
Is there anything on the fitting instructions about those voids? voids normally have to be orientated correctly otherwise it can have adverse affects on wear and handling...
In your picture you have them facing different ways and under load they will react differently... never seen voids in poly bushes before... what make are they?
As above, I hate to be negative, but the voids are incorrectly placed dude, and voided poly bushes are most unusual.
cheaper poly bushes tend to be just the 'press in' variety like this, the better ones like Super Pro are a moulded bush inside an alloy sleeve which presses in much like OE.
Tbh I'm not sure what make they are although it had a grease packet inside that is not for these bushes, the grease was for something else.
They came with as a package I brought (AP Coilovers, powerflex top mounts, wishbone bushes and trailing arm bushes) off the classifieds a few months back. I had no fitting instructions and as my big bush was f*cked I decided to give it a bash. I haven't driven it hard yet but it defiantly seems better..
Would still be looking to get the voided areas aligned as per OE tbh mate...
Not the best pic but its a Mk4 chassis arm (not an S3 cast one granted but its technically the same setup)
Note the direction of the voids on the large bush.. these need to be the same sorta direction both sides else once bedded in the handling could be affected
Yea I drilled them JoJo, then burnt them and then whacked them with a hammer and they fell out. I then cut the collar with a hacksaw then chiselled them out. Cheers for the advice lads I will get them of and see I I can turn them around.
25
5K
W
401
DPM
667
839
Pat
