Strange rhythmic clunking/vibration
Mollygoogle
Darlington
1.9 130. The car has been running absolutely fine until yesterday morning. When I started it up there was a strange vibration through the car, a rhythmic clunking and a rough idle. I didn't have time to look at it so left it until today.
I checked the fluid levels which are fine. Fired it up. It now idles fine. I took it for a short drive and it drives fine. The clunking noise seems to match with the item boxed in yellow moving from side to side. Could just be a coincidence as I'm not that knowledgeable on engines and don't know what it is or whether it is supposed to be moving or not. Any ideas
IMG 0514 zps602f5ec1
Do a search for alternator clutch pulley, if your tensioner is bouncing about will probably be that!
A quick look around on here and watch of vids, etc, shows that this is exactly what it is. Thanks for the heads up
No probs, I did one on a passat a few years ago and the alternator is easy to get out but think you needed a multi splined socket if I remember right on the actual pulley!
You do and they are usually on f****n tight
11
5K
689
643
827
