vag com log
raz83
barnsley south yorkshire
hi everyone
i went to reset my sevice light and thought i would run a log while i was there and quite a few codes come up that i wasnt exspecting, the steering wheel one is ok because i havent got a bluetooth connected yet and the engine and airbag i know about them and was going to sort them in due time but the rest i wasnt exspecting and any help would be good because i dont know if any of them are serious and need to be looked at a.s.a.p
Monday,29,July,2013,19:17:56:45888
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 7D
VIN: WAUZZZ8P65A072032 Mileage: 191780km/119166miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 6337
Revision: 12345678 Serial number: AUX7Z0D9FNI06W
Coding: 0000072
Shop #: WSC 01286 386 08256
VCID: 6CD709E84F38B778ED4
1 Fault Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 226.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 00000000
Temperature: -0.9°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A7BFFB075ECD9C82F8
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 G HW: 8P0 820 043 G
Component: KlimavollautomatH12 0150
Revision: 007962 Serial number: 8P0820043G
Shop #: WSC 06314 000 00000
VCID: 306FDD98A390139891C
2 Faults Found:
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 191780 km
Time Indication: 0
Freeze Frame:
ON
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 218
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001145288
Coding: 00884F06A214100000000000000000000000FE0F5C
Shop #: WSC 00000 000 00000
VCID: 3D71F4AC64C2EEF00AA
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
VCID: 43858254022698007CE
4 Faults Found:
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
001 - Upper Limit Exceeded - MIL ON
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
011 - Open Circuit - MIL ON
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 4189885C183A8A106E2
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
Component: KOMBIINSTR. VDO H71 0210
Revision: D03 Serial number: 2249DD03006098
Coding: 0004408
Shop #: WSC 00762 210 83614
VCID: 4487814807289F38454
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104A04010B
Coding: 3D0F0B40070101
VCID: 285F35F89B405B5849C
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Reset counter: 100
Mileage: 182439 km
Time Indication: 0
Date: 2013.03.17
Time: 13:00:24
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0D9FNI06W
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H07 0220
Revision: 0000013S Serial number: AUZBZ7MD215770
Coding: 0209115
Shop #: WSC 00994 211 10555
VCID: 3467D18857882FB8F54
4 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 135
Mileage: 183001 km
Time Indication: 0
Date: 2013.03.26
Time: 07:21:05
Freeze Frame:
Mileage: 191680 km
Count: 2707
Clock: 15:11
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 182439 km
Time Indication: 0
Date: 2013.03.17
Time: 13:06:48
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 182439 km
Time Indication: 0
Date: 2013.03.17
Time: 13:06:48
02005 - Coding Pin
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 182439 km
Time Indication: 0
Date: 2013.03.17
Time: 13:06:56
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.10 1301
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008000186D288505489AC63000
VCID: F9F9A0BCB06A92D0E62
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000048
VCID: 3E73F3A069C4F5E8130
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209115
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 135
Mileage: 183001 km
Time Indication: 0
Date: 2013.03.26
Time: 07:21:05
Freeze Frame:
Mileage: 191680 km
Count: 2707
Clock: 15:11
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 182439 km
Time Indication: 0
Date: 2013.03.17
Time: 13:06:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 182439 km
Time Indication: 0
Date: 2013.03.17
Time: 13:06:48
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 182439 km
Time Indication: 0
Date: 2013.03.17
Time: 13:06:56
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51C4ECB4A27E70BAA
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End ---------------------------------------------------------------------
thanks for your help in advance
ryan
Is this a smashed car repair?
hi nige
it had a bump a long time ago thats the reason for the airbags the rest quite resently to be honest the only things i have had done to the car is had a new clutch last week and had rns-e fitted just short of 12 months ago, i have cleared all the codes and will give it a few days but just thought it was strange a whole list like that came up.
854
633
656
738
812
NHN
