Twin Exhaust tail pipe finishers on a diesel....whats people got?
Tiffy
Warwick
I have the twin rear pipes, one either side like an S4 but as its the diesel the shoot downwards..
HAs anyone retro fitted tail pipes from different models ect to give it a better look and to fill the hole in the valence
If they're the welded tips, then grind these of & fit the straights.
I have a full exhaust off a fwd 2.0 tfsi (straight tips) if you need it mate.
been quoted £70 from a local exhaust place to chop off the down turned tips and weld on a pair of stainless 100mm tips. should be getting it done next month so will post pics
Tiffy give torqueflow a call they done my exhausts.
Cheers Guys, i didnt know if Audi did some as Parts if you know what i mean......
Here's my attempt Tiffy
Reactions: marky67 and V6 Quatt
Iff audi did tips, they would probably be £456233246 per tip.... or there abouts...
Reactions: Purdy99, unitzero, Molnboman and 1 other person
Mac,
What diameter tips do you have? and where did you get them from?
They look good.
This is what i've had done, was £80 (£40quid each tip, and fitted) they had to lower the exhaust to fit them tho, think these are 3 maybe 3.5 inch, not sure, but most exhaust places should be able to do this fine, i had it done the day after i got the car, as it does look nasty two brown pipes pointing down like the car has impotence!
Reactions: marky67
ive deleted my exhaust but thats just me
Reactions: Macdoon
Cheers Guys, this gives me things to look at.....i think 3.5" will suit mine the best
Reactions: Macdoon
These pics are making me want to replace my downturned pipes. However will these make any difference to the smoke the diesel puts out? Surely it hitting the floor disperses most of it? Would these pipes make it leave more clouds of soot?
Hasn't made any difference whatsoever with mine fella
Don't think it makes that much difference in terms of how much of a cloud you leave... and besides, if you've really given it a bootful, you'll won't be around to worry about it for long!
Lose those droopy tips pronto!
can you get a photo up once youve done it as mines same car and cant decide on it
Here's mine picture quality is terrible but I got 3" tips on mine. Would probs be best to go for 3.5" as I find the 3" is abit to small and the 4" is a little big.
Reactions: Avnt
Same here, running 3", will change to 3.5" just fills the valance better imo.
I want as close to OEM as possible with the sticking out.think 3" would be better for me
shouldn't get clouds of smoke as the b7 has particle filters does it not?
no, mine doesn't have a DPF, so I think mine will smoke more than one with a DPF
3.5" slash cut , deffo should have got the 4"
