vcds Scan result
REDNERRAW72
Hi
Coming home from a trip away i suddenly lost power so a great Audi sport.net member met me today and carried out a scan he is the result,having found the code number on ross teck wiki it says that check hoses pipes,turbo charger /diverter valve and special notes say when found in 2.0 tfsi check boost pressure control valve(N249)FOR CRACKED RUBBER DIAPHRAM.
How much will this cost to sort out?
All advice much appreciated!!
1 Fault Found:
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 83266 km
Time Indication: 0
Date: 2013.05.04
Time: 12:50:12
Freeze Frame:
RPM: 2708 /min
Load: 83.5 %
Speed: 91.0 km/h
Temperature: 78.0°C
Temperature: 19.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 A HW: 8P0 035 192 A
Component: RNS-E HIGH EU H70 0550
Revision: 01S Serial number: AUZBZ7E0900924
Coding: 0209111
Shop #: WSC 01317 552 00000
VCID: 2D549D94B40E3670BAA
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 70
Mileage: 54209 km
Time Indication: 0
Date: 2010.09.08
Time: 18:58:32
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209111
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 70
Mileage: 54209 km
Time Indication: 0
Date: 2010.09.08
Time: 18:58:32
Well, do you have a 2.0tfsi or not?
The N249 is fitted to the turbocharger compressor housing. It is held in with 3 allen head bolts (can't remember what size (5/6mm springs to mind)) The earlier type N249 valve had a rubber diaphragm and is prone to splitting, as the Ross-tech fault code description eludes to, when they get some age on them.
The valve has been revised and now uses a piston type design which has proven to be more reliable. Couldn't say on price though bud.
On the 2.0TFSi engines, it has been known for the PCV valve to fail which in turn causes a boost leak etc.
Regardless of engine, you should check all boost pipe work for signs of leakage. Usually signs of oil around a joint is an indicator of a leak.
Going on the Nav fault codes, you have a RNSE fitted? If yes, it hasn't been coded to the car correctly/at all. Will require coding via VCDS.
Hi Lewis
Yes has a 2005 55 plate 2.0 tfsi S-line mileage now 51940 FSH and yes do have RNSE it was fitted at factory according the the handbook/Bill for car.
RNSE was fitted from factory, but it could well at some point had that RNSE stolen/broken and replaced with another that wasn't coded to the vehicle.
Start by checking boost pipe work for leaks then mate. If they look good, then I would remove the N249 valve and check the diaphragm.
Thanks lewis
Im taking to someone on friday who carried out cam belt change for me.
Anthony
763
fad
