Yes - just take the key apart - lever somerthing into the slot - I can't recall exactly how I then went about getting the insert out, it, but it was easy enough and went ok. I seem to recall taking the battery out (??) too. But as I was replacing it anyway at the same time, that may not actually have been necessary. You'll need to reset the car / key of course.
I think this is what I did - To re programme I put the key in the drivers door and unlocked by turning the key then locked using the key then unlocked using the key fob immediately with the key still in the lock
All sorted, used a watchmakers screwdriver to remove old cover just pops out, put new cover in boiling water to soften up for 30-40 secs, dried and then pushed home new cover into place, all done for £2.70
