Audi S3 EVAP and fuel gauge readings
mmalh0151
Hi all, basically my car has had the charcoal canister cleaned out when it went in for some work at Awesome Gti but now the VCDS is bringing up an emission error to do with the EVAP system (I have cleared this code but keeps popping back up on VCDS)
Now......I put 20 litres of fuel in before and the needle went up to just over 3/4 FULL tank!
Obviously an issue here.
Can anybody advise here please? Is it a valve that has gone or the charcoal cannister blocked again?
A good thread is here....... The Audi TT Forum :: View topic - EVAP canister? N80? ** EDIT: SOLVED I THINK! **
But need to look more into why my car thinks 20 litres of fuel is 3/4 full when it said there's almost no fuel left in the car at all (range said 5 miles and needle was firmly in red!)
Car is a 2007 reg S3 with 63k miles on it.
Any advice would be excellent.
PS- The car is only run on Shell V power and I have not fully filled the car with fuel just yet.....But I did notice a problem last week when i filled 35 litres in it and it gave me a full tank and a range of 365 miles...Obviously not right!
The car is also under warranty through a secondary warranty company but obviously want to try and resolve this before it goes away for weeks on end!! Maybe worth fitting new dials to it or would that be too over the top?
Just has this good bit of info from a Audi mechanic
"Yep, the evap canister can break up causing the fault. There is a basic setting that tests the evap system but i cant remember which channel it is on. Taking the hose off the canister and running the test succesfully will point to a defective canister
I have had a handful where the canister has broken up and blocked the solenoid valve.
As for the fuel gauge, thats difficult to say without testing stuff. Its going to be either the dash insert or the fuel gauge sender, with a small possibility of the fuel pump control unit"
Cheers! Im sure there is something in VCDS that will test it all so may look at this on the weekend or something. If not, its going in for repair!
