Alarm Issues
RainbowShooter
This is my first winter with my A4 and I've been having a few issues with the alarm recently which I'm assuming is down to the cold. The car is locked on the driveway and will the alarm will just randomly go off, sometimes once, sometimes 3/4 times in an hour or two. It started towards the end of last year when the weather changed and has been ok the last couple of weeks until this evening. The only thing I can link it to is the colder weather maybe? Any thoughts?
Scan the alarm with VCDS and it will tell you which sensor or signal is triggering. Saves all the guess work and possible chasing it around.
I'd try disabling the interior sensors and towing sensor if you haven't got quick access to VCDS. Push the buttons on the drivers door before arming. The sensitivity of these sensors can be altered by Audi if these are causing the issue.
You could also close interior vents. Both have worked for me in the past until I got the car into the workshop to alter sensitivity.
However, it may be a different sensor altogether.
364
9
596
