2007 B7 S4 Error codes and problem
ricostuart
Wiltshire
Yesterday the car decided to start misfiring on me. It felt like only 1 of the cylinders as it wasnt too severe. Thankfully only had a short distance to get home. The CEL only started flashing just as i pulled into my parking space. I bought a VCDS cable which arrived today (yay for amazon!). Could anyone please have a look through the codes and tell me whats needing replaced?
I know my rear parking sensors are faulty (dont know what yet, but all 4 dont vibrate - the fronts work fine), and the missfiring. I have now cleared all faults too.
Thanks.
Code:
Tuesday,19,February,2013,11:35:40:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
          69 75 76 77
VIN: WAUZZZ8E45A484660   Mileage: 136880km/85053miles
Address 01: Engine        Labels: 079-910-560-BBK.lbl
   Part No SW: 8E0 910 560 L    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: --------    Serial number:
   Coding: 0011771
   Shop #: WSC 06335 000 00000
   VCID: 2E591061B90C649
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 001 -  - Intermittent
16685 - Cylinder 1
            P0301 - 001 - Misfire Detected - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 002 - Voltage too Low - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09L-927-760.lbl
   Part No SW: 8E0 910 156 M    HW: 09L 927 156
   Component: AG6 09L  4.2L5V RdW 0040
   Revision: --H01---    Serial number:        0087083
   Coding: 0000001
   VCID: 30650E19A338729
No fault code found.
Address 03: ABS Brakes        Labels: 8E0-910-517.lbl
   Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
   Component: ESP8 quattro    H04 0180
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0004902
   VCID: 2757E54596F6351
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 40
                    Time Indication: 0
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x00FF
                    Hex Value: 0xFF92
                    Hex Value: 0x00FF
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 AM
   Component:   A4 Klimaautomat   2731
   Coding: 00000
   Shop #: WSC 00000
   VCID: 6CDDDA691C90D69
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 J
   Component: int. Lastmodul  ECE 0303
   Coding: 01021
   Shop #: WSC 06335
   VCID: 3973333D2342B31
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
            49-10 - No Communications - Intermittent
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036M002A76D
   Coding: 0033722
   VCID: 3B7F29357A7E811
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 Q
   Component: Lenks·ulenmodul     0601
   Coding: 04141
   Shop #: WSC 06335
   VCID: 41835BDD4B92EB1
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 981 P    HW: 8E0 920 981 P
   Component: KOMBI+WFS 4     H12 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0007441
   Shop #: WSC 21438 210 72067
   VCID: 3A712C317644B89
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 8E0 035 192 C    HW: 8E0 035 192 C
   Component: RNS-E HIGH EU   H53 0650
   Revision:      08S    Serial number: AUZBZ7D0405753
   Coding: 0301217
   Shop #: WSC 00836 210 61229
   VCID: 244DF249E4C0DE9
1 Fault Found:
02261 - Data Medium
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 5
                    Fault Frequency: 14
                    Reset counter: 15
                    Time Indication: 0
                    Date: 2013.02.01
                    Time: 17:45:55
             Freeze Frame:
                    Mileage: 655350 km
                    Count: 802
                    Clock: 09:24
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   Shop #: WSC 00000
   VCID: EBDF5975999E511
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BM
   Component: Komfortger·t T3B    2431
   Coding: 06907
   Shop #: WSC 06335
   VCID: 7DFBE72D77EA4F1
   Subsystem 1 - Part No: 8E2959802B
   Component: Tırsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E2959801B
   Component: Tırsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tırsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tırsteuer.HR BRM 0205
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
00962 - Alarm via. Tilt Sensor
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
00956 - Key 2
            35-10 -  -  - Intermittent
00532 - Supply Voltage B+
            37-10 - Faulty - Intermittent
01331 - Door Control Module; Driver Side (J386)
            80-10 - Single-Wire Operation - Intermittent
Address 55: Xenon Range        Labels: 8P0-907-357.lbl
   Part No: 8P0 907 357 B
   Component: Dynamische LWR  H01 0020
   Revision: 00000001    Serial number:
   Coding: 0000005
   VCID: 3973333D7042B31
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0301217
1 Fault Found:
02261 - Data Medium
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 14
                    Reset counter: 15
                    Time Indication: 0
                    Date: 2013.02.01
                    Time: 17:45:55
             Freeze Frame:
                    Mileage: 655350 km
                    Count: 802
                    Clock: 09:24
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 C    HW: 8E0 919 283 C
   Component: Parkhilfe 8-Kan H06 0020
   Revision: 00H06000    Serial number: 00067802130435
   Coding: 0001104
   VCID: 30650E19A038729
5 Faults Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 31
                    Reset counter: 81
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2000.01.01
                    Time: 00:00:00
01548 - Sensor for Parking Aid; Rear Right (G206)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 22
                    Reset counter: 211
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2000.01.01
                    Time: 00:00:00
00466 - Control Module for Steering Column Electronics (J527)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 41
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2000.01.01
                    Time: 00:00:00
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 3
                    Fault Frequency: 90
                    Reset counter: 169
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2000.01.01
                    Time: 00:00:00
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 41
                    Reset counter: 248
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2000.01.01
                    Time: 00:00:00
Address 77: Telephone        Labels: 8P0-862-335.lbl
   Part No SW: 8P0 862 335 D    HW: 8P0 862 335 D
   Component: FSE_255x BT     H18 0050
   Revision: 00000001    Serial number: 00000000177179
   Coding: 0001822
   VCID: 377735054556A51
End   ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 37: DTCs cleared
Address 45: DTCs cleared
Address 46: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
Thats a fake non genuine illegal cable, the forum does not support the use of said items, I suggest you return it & ask for a full refund & buy a genuine version as it cant be updated, not warranted by RT, not entitled to support from RT.
905
4K
5K
NHN
