Not really no... all it really does is make the std pump work harder and fail sooner... S3 injectors on a 3bar FPR will fuel for around 280hp... well within the realms of all but the most extreme K04 setups... only Westy has managed to surpass the std injector flow so far on a K04...
If more fuelling is needed then its better to fit larger injectors than a 4bar...
Rods are peace of mind... as always
NLS may be the bigger parts breaker than launch boost build tho... so maybe that and not NLS is more appropriate unless you are happy taking the risk and signing a disclaimer..
