Noticed it when I got q nail taken out of my tyre.anyone know what it could be?I had my rear beam bushes replaced for powerflex bushes about a year ago but I'm not sure what it causing it.anyone had this?
Your car properly needs a alignment.
Once the wear has started you cannot stop it, you would be best putting 2 new tyres on the axle then finding your local garage with a Hunter alignment machine then they can Set you car up to manufacture spec or to any other spec also give you a print out of before and after. If you cannot find a hunter machine then make sure its a 3d alignment. This is what I did and it stopped my tyre wear.
I use a garage in Peterborough called Monarch Automotive after reading a good review on this forum worth a search for your local garage.
Marty has a golf, the rear is 100% non adjuatable.
Marty: I'd get yourself down to a tracking place, and have the back end checked out. If it's within factory specs it shouldn't wear. Perhaps your beam is a bit out....
I got it aligned a few months ago and I'm beginning to wonder what was actually done as im sure its been there a while? I'll get the a different garage to check over it,new tyres while in at it.
