Hi all,
A household car has 2 fault codes of which have been cleared numerous times and keep returning.
The first fault is clearly something to do with the engine fans, but before spending a decent amount on a new set is there antything else that could be the issue (as opposed to failed units)?
With regards to the second fault, I am completely stumpped as the car starts, drives and runs fine (without any obvious issues).
Does anyone have any tips of what these faults are, how to test them or even how I can potentially resolve them?
Thanks,
Luke
1 Fault Found:
18354 - Control Module 1 for Coolant Fan
P1946 - 000 - Defective
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00101100
Temperature: 18.9°C
Duty Cycle: 9.6 %
1 Fault Found:
01177 - Engine Control Unit
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Thanks,
Luke
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00101100
Temperature: 18.9°C
Duty Cycle: 9.6 %
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
