Gearbox off ???
Sy.S3
Hi all. Was looking for a bit of help. I have a 51 plate S3. The clutch pedal stuck to the floor, I was told the common fault was the master cylinder. I changed it. Then the T-section breather was sucking air in around the bleed nipple, I also noticed fluid dripping from the bell houseing of the gear box. I have changed the breather with my fingers crossed. There I a good clutch peddle now BUT there is still fluid leaking from the bell houseing. So my next job is the slave cylinder I think.
Was wondering if I was right with the slave cylinder and are there any special tools I need. I'm gonna get a spline socket set for the shafts.
Thanx and is there anything else I should know.
Take it nobody's got any useful advice then.
mate maybe put a picture... check your oil levels... im not the most experienced ASN member here but im sure some will help ..
btw there are a few threads about there peddle stuck to the floor if you have a quick search too.
S
35
6K
699
14
811
