Polo 6n2 cutting out with error codes
Nilz
Defo worth the wait :)
Did a scan on the wifes polo earlier as she said that it keeps cutting out intermittently, the below faults came up on it. This has been going on for a while now and I have already replaced the camshaft sensor and its still the same, someone else mentioned it could be the crank sensor (?)
Can anyone advise at all on the below please?
3 Faults Found:
00519 - Intake Manifold Pressure Sensor (G71)
31-10 - Open or Short to Ground - Intermittent
00513 - Shareware Version. To Decode all DTCs
03-10 - Please Register/Activate - Intermittent
00282 - Shareware Version. To Decode all DTCs
26-10 - Please Register/Activate - Intermittent
Thanks in advance
Nilz
first clean out throttle body and reset
remove map sensor and clean first but you may need to replace
also check cam timing if 16v engine as this fault can come up if timing slipped
8K
NHN
4K
5K
NHN
581
