Haldex Oil Change (I HAVE SEARCHED, HONEST!)
Brad.
Riiiight, my Haldex is well overdue an oil change.
Car is an 06 Audi A3 2.0tdi Quattro
When i've been reading i'm getting confused, and as of yet. I've unable to find actual part numbers.
I've been in contact with TPS and i've been given these part numbers:
Oil: G 055 175 A2 it isn't in the special tube. Just in a normal oil type container. It says 'High performance oil for Haldex Coupling'
Filter: 02D 598 574. Again i'm not entirely sure if this is correct.
Now after reading this looks to change the oil in the whole haldex system. Does this need to be done every 40k?
After searching around, i've found the oil *should*? come in the silicone tube style container?
Is there any chance any body in the know could sort me some part numbers.
Thanks!
Just remember the rear diff has two oils,the haldex filter and oil for the coupling which you need to force in from the underside and it needs to be in the mastic style tube to be filled,then the diff part which is just the normal diff oil EP80/90? unsure to be fair on oil weight ..
9
875
