Hi all is this the right EGR delete kit?????
You'll get a code on some cars as your ecu will expect to see a lower maf reading than what it's getting with the egr disconnected.
Just block the single one to the egr to try it. If it works and causes no elm then remove all vac lines related to the egr and asv.
So in short, are these allard kits worth fitting and what else needs to be done/ purchased, I am suffering crap mpg but am just about to change the air mass meter.
Just like me last filll i averaged 30.5 MPG!!!!! but it was all town driving + cold weather...........I mite but an ALLARD KIT JUST TO BE SAFE.....................
Blanking the egr won't make a lot of difference mpg probably about 2 to 3mpg if your very lucky
Hi,
Im think of fitting a EGR delete and upon reading the above could someone confirm it the engine management would come on with a awx 2002 52 plate?
sam
Hi,
sam
I wouldn't think so mate, I've read it to be cars 2003 onwards that the EML could come on. I would go for an EGR blank rather than delete the valve, as I understand it the EGR also houses the Anti Shudder Valve which stops the engine when you turn the key off by starving it off air. If you turbo seals fail and the car goes into a 'runaway' there would be no way to stop it without the ASV.
Mines the same engine and year as yours, im going to disconnect the vac pip and block it. This will leave the EGR valve closed. To be sure fit a blanking plate to the lower end of the EGR feed pipe. Job done.
If your cars newer than an 03 plate you WILL get the EML light. Also if your just blanking the pipe off and not fitting a delete you should leave the ASV valve plugged in.
Has anyone bought one of the blanking plates and gasket off ebay? Im guessing they'll do the job ok?
My dad made mine for me, there is a how to for the blanking plates in my thread, but I forgot to put in about blocking the vac pipes, and I can't edit it for some reason.
I used just 2 blanking plates and a bolt in the pipe. Left actuators plugged in. On an 03 plate and had no issues. I only did it to avoid all the crap reoccurring after cleaning the intake manifold. Haven't noticed any change to the mpg at all but it did feel more responsive and pulled better. I put this down to all the cleaning I did rather than the egr blanking.
You can also go down the route like some of us with later 2004 cars that get the EML light when the EGR is disconnected by changing the gasket to a smaller holed one off a Mk3 Ibiza. It restricted the flow of gases getting to the EGR but allows enough not to trigger the EML.
Hello everyone my 1.9 130 runs good, I'm well chuffed with the whole car to be fair.
Would you guys advise leaving the egr system as standard, or would you go down the egr delete route before any issues start?
Thanks, Mark.
The EGR system has the anti shudder valve attached and the delete kit removes it......personal choice but I would rather disable the EGR by removing and bunging up the hose and keep the anti shudder
Reactions: wheymonster
Could you direct me to a write up as i dont know where the EGR is
Could you direct me to a write up on how this is done? How hard is it to do? Parts cost etc
If it's not left then maybe it's bottom right for the 2.5, not entirely sure but it's an easy find just take off her clothes and look for that magic metal mushroom tip.
ok cheers mate! So its as simple as unbolt and clean yeh? ive also read on here that to take it off and clean, you haveto replace the gasket... did you haveto?
I bought 2 blanking plates off ebay formy 52 plate 1.9 TDI 130 about £2 each. Did the Mr. Muscle turbo vane clean and removed the EGR pipe completely as it gets in the way and is a pain in the butt. Not sure why anyone needs to pay £50 for a kit.
Will you fill me in on the Mr Muscle turbo clean?
771
20
8K
833
952
