Picture of drivers door with panel off needed.
hobo_mofo
Hey all,
I needed to replace my driver side door release cable over the weekend but a piece of metal fell out when i took the subframe out. I think it was a shim because now my door does not alighn properly.
I have no idea where this fell from and would be great if someone could take a picture of their drivers side door with the inside panel off.
cheers
grant
There is a shim on each corner at the bottom of the subframe which fits between the frame and the door. You will need to adjust this until you get the position correct given that it fell out and you wouldn't have marked at what position it was in originally. I've attached a pic of one.
