Removing ear clips
rasA4
Four Rings Mafia Specialist
Deep
Dunno how else to describe them. Trying to remove thesedamn clips from expansion tank
It's fiddly and keep slipping off what do u guys use?
Tried both keeps slipping there is a special tool but costs over £30 WTF
Same as tony. its a bit of a pain.
but you want a pair where the jaws remain as flat as possible.
A screw driver helping to nudge the button of clip helps as well.
EDIT:=-
Set of theses seems to work best for me
yep used that
not up to the job tbh looks like ill have to buy some new clips now
ill try the screwdriver thing knowing my luck ill pierce the hose, lol
I use pump pliers. similar to what your pointing to in the pic, but slightly thinner and the jaws remain flat in all notches. Have never had a problem using them.
Same here, some clips are worse than others, but i usually manage with water pump pliers as arrowed or a normal pair of needlenose or stub nose pliers.
I've used the proper tool, and its really good, but its a lot of money for something thats used occasionally.
716
3K
654
906
