VCDS / VAG COM KENT / SE LONDON
doug.p
Dartford
hi
i am normally in the a4 forum so hi to all of you.
i needed to code my a4 recently so i purchased VCDS from ross tech
i can now code all VAG cars in full, so if you need anything coding, then drop me a PM
i am based in rochester but can cover kent and se london
will be much cheaper than a garage or a dealer
just thought i would try to help anyone who might need it​
Hi there , can you advise if i will need to have my lights re-coded, and what exactly that involves as i dont understand?? Basically i updated my cabrio B6 Audi to B7 facelift 2005-08 version, when i changed the headlights there is error faults and lights dont work properly at all?? help?? Thanks
For a start this is the wrong section for your query & 2nd, its probably a collection of various things, wiring & coding, PM me about your conversion & I will see if I can advise as I do the wiring & coding of number of these conversions :)
3K
NHN
935
710
