Hope this helps...it's not complete but is drawn from various sourcesm should cover all A3/S3 1.8T variants /ubbthreads/images/graemlins/book.gif
Engine code AUM is what you need for a UK sourced VVT and DBW car
110 kW (150 bhp) Engines in A3
AGU
12/96 - 07/98
Drive: FWD
Emission: Non-VVT, EU3
Throttle: cable
Injectors: small
Turbo: K03
Gearbox: EVS, EGY
AQA (not available in UK)
Date: 08/98 - 04/01
Drive: Haldex 4WD
Emission: ?
Throttle: ?
Injectors: big
Turbo: ?
Gearbox: ?
AUM
Date: 05/00 -
Drive: FWD
Emission: VVT, EU4
Throttle: drive-by-wire
Injectors: big
Turbo: K03sport
Gearbox: EBN, ENJ, ESV, FDC
ARX (Not available in UK)
Date: 09/00 -
Drive: Haldex 4WD
Emission: VVT, EU3
Injectors: big
Turbo: K03sport
Gearbox: FEX (5-speed, short gearing)
ARZ
Date: 09/00 -
Drive: ?
Emission: VVT, EU3
Injectors: big
Turbo: K03
Gearbox: ?
132 kW (180 bhp) Engines in A3
AJQ
Date: 11/98-08/00
Drive: Haldex 4WD
Emission: non-VVT, EU3
Throttle: cable
Injectors: big
Turbo: K03
Gearbox: ? (5 Speed)
APP
Date: 07/99-05/00
Drive: Haldex 4WD
Throttle: cable
Injectors: big
Turbo: K03
Gearbox: ?
ARY
Date: 09/00 -
Drive: Haldex 4WD
Injectors: big
Turbo: K03sport
Gearbox: FHA, FEK (6-speed)
AUQ (not available in UK)
Date: 05/00 -
Drive: FWD
Emission: VVT, EU4
Injectors: big
Turbo: K03sport
Gearbox: EHA
154 kW (210 bhp) Engines in S3
APY
Date: 11/98 - 09/00
Drive: Haldex 4WD
Emission: VVT (mechanical), EU3
Injectors: big
Turbo: K04
Gearbox: ? (6-speed)
AMK
Date: 09/00 - 04/02
Drive: Haldex 4WD
Emission: VVT, EU3
Injectors: big
Turbo: K04
165 kW (225 bhp) Engines in S3
BAM
Date: 08/01 - 05/02
Drive: Haldex 4WD
Emission: VVT (check), EU3
Injectors: big
Turbo: K04
The easiest way to tell if you have a drive-by-wire throttle on your Audi/VW/Seat/Skoda is to simply look for an 'EPC' (Electronic Power Control) light on the dashboard when you turn the ignition on. All A3s from facelift MY01 have DBW but not necessarily VVT.
To tell if VVT when looking into the engine compartment from the grill, look to the right side of the engine block and there'll be a black cylinder mounted. This is part of the crank sensor. The sensor itself is on the other side of the engine.
