Because of the clear panel on the facelift lights you end up having a clear lamp as your indicator so you just switch the bulbs over. The headlights are a little bit trickier because you have to cut a little bit of the inner wing away with a little dremel type drill plus the connectors on mine were different which was just 10 second swap around of my old xenons you should do the fronts as well it just transforms the car mate I got a set off fleabay for 200 quid. But if you buy some make they have the ballasts with them as well. Front and back lights 3 to 4 hours work. Well worth it though hope this helps you mate... Rob
