Hi i was wondering if anyone knew of any firewall/grommet locations on a audi A3 2007. I need to feed a few cables through the firewall but want to feed them through an exsiting grommet etc
can you not follow the loom from engine in? iknow on my a4 that on driers side under the black box theres a grommit there that has shedloads of wires coming threw.?.?.
The best way isnt the quickest. If you remove the wiper arms, scuttle tray & then wiper motor there is a panel that when removed gives you complete access to the inside of the car above the central electronics module & where the fuses are. It seems a bit daunting but its not hard and gets easy after you have done is a few times.
khufu im with you on that i found the hardest part of the whole removel process was removing wiper arms without damageing anything they wher well stuck on but part from that its easy and the best bet to go with
