Suzuka S3 8p
Currently have a dreaded fault with my Audi s3 tfsi 2010, P2188 code bank 1 to rich at idle, I have read on here about this being discussed previously but I am running short of answer’s now, the car is absolutely killing fuel off for fun, 40 miles range to a quarter of a tank of fuel driving sensible, many parts replaced and still can’t get to the bottom of the fault, had two different Audi tech’s look at it who is also scratching there heads with it aswell as it’s showing no symptoms with drivability of the car other than this dreaded code but them em pointing towards this then that then the other and not diagnosing the fault, Bank 1 to rich at idle P2188 I’m just chucking money at it chasing this dreaded fault as there are no symptoms with the drivability of the car, It doesn’t idle unsteady at all on tickover, there’s no misfires, it starts on point wiv turn of the key without hesitation, it still pulls and boosts fine with no lack in noticeable performance issues, other than the oil stinks of fuel when u open the oil cap although no signs to have risen on the dipstick to confirm which is strange considering the amount of fuel it’s dumping or going somewhere, here’s what’s been replaced so far parts wise,
New plugs
New air filter
Oil and filter change (only lasted 3 days after code being reset to detect oil contaminated with fuel again on Odis wtf)
lambda upper one back of engine
Maf sensor
Air inlet temp sensor
Crankcase Pcv valve
N80 valve
Charcoal canister
Cam follower and second hand pump aswell thinking the internal seal on HPFP may be leaking and contaminating the oil,
The only thing not been done is the injectors tested which I don’t really wanna chuck more and more money at it to find it’s not that at fault and it’s some daft sensor or a dreaded electrical gremlin problem, I’m really starting to loose patience with this car now as no one can put there finger on the issue!! Any help or recommendations Guys on this would greatly be appreciated.
Other than burn it
New plugs
New air filter
Maf sensor
Crankcase Pcv valve
N80 valve
Charcoal canister
Other than burn it
