whats it like with loudness turned off . i find theirs hardly any bass at lower volume with it off and volume is a bit lower
ok m8 .. have you had a look in the equaliser settings ?
just had a play with mine m8 its nearly 2am here so cant crank it up . but in the factory settings i changed the amp volume to -10db and it did lower the volume a bit so with volume at 1 it was quieter . dont know if it effects higher volumes though.
eddo
how bad is the feedback, is it a constant or only when on low volume?
You need to request from xtrons a separate ISO harness with impedance converters on. You adjust the dials for the front and rear speakers in order to eliminate the interference.
What rca’s are those though? I don’t have any rca’s at all
what is the S button for ?You need to request from xtrons a separate ISO harness with impedance converters on. You adjust the dials for the front and rear speakers in order to eliminate the interference.
Hi @JayA3sline , did Xtrons provide the harness FOC? last time I contacted them re the whine they gave me a software update :/
They haven’t done anything for me. They take FOREVER to respond. I’m actually going through the eBay store xtronsusa where I bought it. Xtrons factory hasn’t responded to my original email yet. I’m thinking about just returning the head unit. I love it, but the buzzing whining is absolutely horrible.
They have a office based in Leeds but obviously everything goes through China. Remember due to this virus and also the Chinese New Year hasn’t helped issues at all. They contacted me a couple of days ago for an issue I requested few weeks back. Admittedly you have to be patient with them due to the time zone.
The impedance converters will sort out your humming issues.
I just checked my emails @Stevemwhitaker (granted it was in 2018) but they got back to me the following day with the firmware update. Going through the chain their final suggestion was that I might need an Engine Suppressor to kill the whine. The email address I used was techsupport@xtrons.com
@JayA3sline, you didn't mention if xtrons supplied the filters for free or not?
They did indeed but I did specify that they include them when I ordered my unit.
I seeeee....and they sent you the thing in the picture in post #55?
I will throw a hail mary n see if they play nicely with me after all these years, failing that I will see what the interwebs have to offer.
Correct. Albeit there’s 2 of those adjusters on the harness front L & R and rear L & R.
Soooooo... I got a response from xtrons, but they say the updated harness is only applicable to Audi units with serial numbers IB or IN.
My thinking though is, if they have recognised that there is an interference issue and have modified some harnesses, surely they should provide a solution to all models??
Cheers @Stevemwhitaker.
I had abit of back n forth with Xtrons, n they pretty much said if you have the PBX model you're on your own, they only have a fix for the IB & IN models. Sounds like a violation of the sale of goods act if the product is not fit for purpose, but I am not sure how valid that is for overseas items :s
Good Luck with your revised leads!
