Help identifying part
Jamesh87
Hastings
looking to take off the ramair induction kit that came with the car i recently got (2007 2.0tfsi) and went to fit the standard airbox back on and it seems to be missing a rubber sleeve or something that goes on the oe intake pipe to secure it on properly as now it just flops around when secured on the engine end?
Best to post a pic off where you think your missing something as pic helps us get a picture off the part .
Attached a pic, not near car so cant take proper one have circled in orange where rubber bit needs to be
On my Tsfi that looks like a spring clip which attaches said hose to Turbo if I am not mistaken , but if it ain't am sure someone will be along to put me right lol
I have the intake pipe and the spring clip(which is a ****** to get off!) but where that pipe slides over im pretty sure there is a rubber bit that slides in first, as now if i try to put it on its just floppy
Reactions: Daveyonthemove
There is a rubber seal that joins the pipe from turbo to airbox next to maf sensor where it has 2 clips which pull it together
Not that maf sensor end its engine end, the end ive circled if i slide that on and do clip its just floppy, im sure on my old a3 it had a rubber bit too
Yes, it's the end that fits to the Turbo, and the oval shape attaches to the airbox just after they MAF with the two clips.
Maybe if i order whole pipe it will come with it then
I'm not sure it does, I did originally post a number for a pipe that I thought had it included, but after checking further I couldn't see it.
That part is only £10 on ebay, but call a dealer to confirm it's the right part for your engine as I can't be 100% sure.
@Jamesh87 - when I sold my factory cover I thought I'd lost this exact piece - it's like a sleeve that sits onto the turbo, then the plastic down pipe slides over. For me, it was wedged into the main piece of down pipe - worth a check?
Reactions: Jamesh87
I did have a check sam but no joy :-( been a right pain trying to think of what its called haha
Reactions: samuelh_888
Funny enough I probably have it as I kept all my oem box but where it could be is the question , but if I come across it I will mind what it's for now
Reactions: Jamesh87
Not sure 100% if that’s what you mean but the only numbers on it are 669 850 0
Only changed intake to revo the other week so haven’t put all the oem bits away yet lol
Bi bryant thats certainly the little ******! Many thanks for pic and numbers, and everyone for their help
Reactions: abmat and Daveyonthemove
How come you reverting to standard airbox......do you not like the ram Air?
Gaz
just prefer the standard airbox less noise, feels like
Less torque with the ramair too, car is completely standard maybe different with a map but that isnt going to happen anytime soon
where abouts are you? I would of swapped you my standard set up for your Ram Air set up?
Yes thats a fair old trek lol, when the bit turns up for standard one it will be up for sale mate
