Agree’d only real one out there worth considering is Badger5’s ones. Oversized check them out.
I know it, but I have a problem. My car is LHD and does not fit...
I see your problem, I’m sure I read somewhere you can get them to fit with a bit of trimming..... it’s the pipes from the brake servo that’s the issues isn’t it from memory?
Here is a homemade 76mm inlet for LHD. 2 silicone elbows - 51 -76mm; 76 -76mm and the metal pipe(76mm) needed to be bend a bit in oval shape due to master cylinder pipes.
You can make the one from Bill Badger fit as well just have to trim it a bit. Had some pictures but no idea where they are now. But it does fit.
quite a few have fitted itFor LHD doesn't work
Precisely.. I will make a custom 3" inch TIP for LHD and I will share here!quite a few have fitted it
its not easy or great tho.. lhd brakes get in the way a lot
