I want to try to update maps/software on my rnse as it just shuts down when power is on fine when ignition is off but as soon as it comes on it goes, anyone done this yet? Will the software update prevent me from coding it to a a6
Clutching at straws really! I need to update maps anyway but since I got it decoded ( thought I forgot the code turns out I didn’t just wouldn’t accept it) it won’t work when ignition is on so don’t know if it’s corrupted the software or weather or not is the mfsw install, but when I disconnect the bt loom where I done the connections it still doesn’t work with the ignition on. So hopefully I can spend a few hours tomorrow and get it sortedWhat are you trying to do exactly?... you should be able to just use the latest map disc... no need to flash the RNS-E at all
<tuffty/>
