So I swapped out my front spacers from 8mm to 10mm - the bolts were 35mm do I need longer ones? I have looked online but cannot are anything 37mm only 40mm as the next length up ...
The rule of thumb is to add the width of the spacer to the length of the original bolt. Better to be too big than too small. You will see on the bolts you have been using where the threads have reached. Replace a bolt without the wheel on to check there is enough clearance for the extra 3mm.
