Help
Jonboymma
Manchester
Hi, I'm new to here and could use a little advise please? I've got an a4 2.0 tdi, it's been remapped. It's having some starting issues. Usually first start of the day is fine, after that, there's an intermittent fault. Sometimes it doesn't start first turn, it just kind of clicks once and then nothing. Sometimes it will start a few seconds later or needs a bit longer sometimes. I'm not mechanically minded much, but I'm thinking starter motor related? I've been advised it could be coolant temp sensor but the temp gauge on dash seems to get to temp fine? Thanks in advance for any help
A click when turning would normally point to a starter motor issue although you may need to plug it into VCDS to confirm there aren’t any other issues first
439
712
322
399
