Hi guys my boot won’t open the only way to do it is manually by climbing in the boot and pulling on the release latch.
So far I’ve change the handle on the outside and the actual latch its self but even so after that when you unlock the car nothing happens to the latch (it doesn’t move) and when you pull on the handle same thing nothing.
The rear wiper motor was leaking so I’m guessing it has something to do with that is there anything else I can test? Maybe use a volt meter to the connector that goes into the latch and see if it gets power when I unlock the car? Does anyone know which pins I should be testing as there’s 4 and what to turn my volt meter to?
Thanks guys.
Thanks guys.
