B12
Bilstein B12 Pro-Kit Suspension Kit - Lowered Ride Height, Fixed Damping
The Bilstein B12 Pro-Kit Suspension Kit is what you get when you combine industry leading dampers with the winning name in performance springs. It is the ideal suspension kit to fit-and-forget. The fixed rate legendary Bilstein dampers (B6 Sport or B8 Sprint depending on application) are matched to the winning performance of Eibach Pro-Kit springs, giving a kit that will transform the looks and handling of your car - giving less body roll And vastly improved dynamics. Simply put, a great handling car for fast road use, with a lowered stance.
The Eibach Pro-Kit springs lower the car approx 25-30mm, And the dampers are fixed rate. There's nothing to adjust, so you can fit and enjoy. No damping rates to adjust, no ride heights or corner weights to adjust - Eibach And Bilstein have done all the hard work so you don't have to.
The Bilstein B12 Pro-Kit is the perfect choice for those wanting the highest performance, mildly lowered suspension kit (25-30mm), without any hassle of adjustability. For a more aggressive lowered stance (45-50mm), choose the Bilstein B12 Sportline suspension kit.
On vehicles where sports suspension is a factory option (e.g. Audi S-Line, BMW M-Sport, Mercedes AMG-Line) the lowering amount shown is for vehicles without. If your vehicle has optional sports suspension you will have to deduct the amount the vehicle is already lowered by. This can be up to 30mm.
B14
Bilstein B14 PSS Coilover Suspension Kit - Adjustable Ride Height, Fixed Rate Damping
Bilstein B14 PSS Ride Height Adjustable Kits are an adjustable ride height system front And rear, with factory tuned, fixed rate damping. Bilstein's extensive motorsport experience And Original Equipment damper manufacturing has enabled them to produce a range of coilover suspension kits that are specifically designed for each application And suited perfectly for performance driving on the road.
The B14 PSS Coilover Kit's gas pressurised damping has been optimised for fast road driving - good ride quality at low speeds, ultra stable at high speed, And suitable for everyday use. The triple C Technology used for surface coating gives long lasting corrosion resistance, And the round threads And special alloy spring plates enable easy height adjustment for years to come.
- Bilstein's Mono-Tube damper technology
- Triple C coated coilover housings for long lasting corrosion resistance And good looks
- Round threads And special alloy spring plates for easy height adjustment
- Designed, developed And tested for each application
- Supplied with necessary bump stops
- Excellent suspension travel retained - a must for decent hAndling on poor roads
- German TUV certified, made in Germany
Note: Coilover height adjustable units are supplied front & rear where possible. Where rear suspension design does not allow for coilovers, alternative height adjustable or lowered units are supplied.
On vehicles where sports suspension is an option, lowering amounts shown are for vehicles without sports suspension. If factory sports suspension is fitted, the factory lowering amount will have to be deducted from the lowering amount shown. This can be as much as 30mm (e.g. Audi S-Line, BMW M-Sport, AMG-Line etc.)
Depends on what you use it for , would be interesting to find out spring rates .
B14 for a not cheap coilover is still only fixed rate damping .
