I already did route the given wiring from Stalker to Bulkhead T10e connector from inside the car under the steering column to the empty pins on the black connector as following the given order.
Blue - Pin 1
Red/Yellow Stripe - Pin 2
Black/Yellow Stripe - Pin 3
White - Pin 9
