My mapping day didn't go as planned
Andrew@A.L.D May 8, 2012
  1. Andrew@A.L.D
    3,877
    617
    Fitted the Wideband ecu and did everything was needed, we fitted a RS4 maf in the end and had to cut wire 63? to the ecu to stop fans kicking in all the time
    has some problems with the immobilizer to start with then bang its started up, took some time to get the idle right and fueling too, Paul did a run with just 10psi and it made an extra 20bhp from the inlet i made from last time it ran 10psi on the narrow band.
    We were about to turn up the boost when it sounded like one of the pulleys bearing for the timing belt started to make a loud squeal and at that time we said we would just end it then at 8 pm
    Not as i planned but i'm glad its not the engine making that noise and its just some sort of a bearing in the pulleys?
    So Andy Speck will be having a look at it tomorrow to see what the noise was
    Paul did say it was looking good and will do 500bhp, Paul was very nice to give me a lift home in his 511bhp R26 megane !!! and i must say that that thing blood shifts !!! I am going to look forward to having 500bhp for myself
    Paul also recommend fitting a boost controller so i'm not running 30psi and 500bhp all the time
  2. superkarl
    superkarl MAN OF STEEL
    9,423
    2,382
    i was looking forward to your results. shame. at least its simple...so far.
    511hp in a megane?!!! how on earth can that put it down lol
  3. Andrew@A.L.D
    3,877
    617
    Me too but i do hope its simple myself I just can't afford a major problem with it right now
    The megane has a great chassis and he does have some R888 on the front but they were still cool also he was running low ish boost at about 1 bar for 430/450 bhp ish so not quite 511bhp when i was in it but still bloody fast
    Lizard-Racing likes this.
  4. superkarl
    9,423
    2,382
    what pulley is the dodgy one?
    i thought it was widely accepted that these aftermarket crank pulleys dont go well with the 1.8t? is that wrong?
  5. <tuffty/>
    20,999
    3,764
    Builds like this never go to plan mate... always something and generally always come to light on the dyno... I am sure you will sort it though... :)
  6. Andrew@A.L.D
    3,877
    617
    Its not a light weight crank pulley that's on it
    Its a fluidampr pulley, they heavier than the standard ones and are better for are engines
    We think it's one of timing belt pulleys?
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Im in on the 16th Andrew, for my Map, hope you get it sorted...:icon_thumright:
  8. Westy
    Westy Well-Known Member
    17,443
    1,103
    Hope you get this sorted tomorrow Andrew. Looking forward to this.
  9. Andrew@A.L.D
    3,877
    617
    Me too lots of time and money in this build now to give up
    Looking forward to having 500 bhp in the s3 after a run in Paul's r26
  10. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    There's always something, better luck for tomorrow!
  11. Andrew@A.L.D
    3,877
    617
    Not sure it will be finished off tomorrow but if it is it's all good
  12. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Seems to be my favourite recommendation at present but sure it's not the PAS fluid being low? Can sound like just about anything including engine noise. Sure you've topped yours up but thought I'd mention it.
  13. Andrew@A.L.D
    3,877
    617
    Last time I looked it wa full and that was about 2 weeks ago
  14. badger5
    9,424
    1,972
    i doubt you will need 30psi to >500bhp............ not with your spec
    mid 20's on mine gets mid 500's on 1900cc
  15. Andrew@A.L.D
    3,877
    617
    I'm still on standard cams and it doesn't rev live a 1800/1900
    When it did its first run on 10 psi it made 280bhp at 6500 rpm, it didn't seam like it wanted to rev
    But we'll see?
  16. badger5
    9,424
    1,972
    If its anything like the stroker hta3071 LCR which we did a few weeks ago, yours will be a monstor..
    summats holding it back if 10psi was only 280bhp tho.. My 12psi actuator pressure on my ibiza is 360bhp on its hybrid gt35 on 1900cc. I expect the map is holding it back, and when its finished, it will be mental...
    I only revved the 2ltr stroker to 7800rpm max, peak power on it was just over 7krpm as a comparison. (my 1900cc has 8800rpm hardcut, 8500rpm softcut)
    whens it back and being mapped? or is it still there?
    really looking fwd to hearing the results from it.. super spec.. and 4wd.. Nice.
  17. Andrew@A.L.D
    3,877
    617
    I left it there for them to fix the pulley.
    When we left it he had only just got the base map sorted and working on it a bit more so it was still early days
  18. Andrew@A.L.D
    3,877
    617
    Say if I was going to run 30+ with my spec what would you think it will do
  19. badger5
    9,424
    1,972
    my guess would be 630bhp potential with a bucket load of torque from your 2.1
  20. Paradox1
    Paradox1 Active Member
    1,833
    88
    Do IT:racer:
  21. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    hang in there mate will be awesome when its done! :)
  22. superkarl
    9,423
    2,382
    DO IT
    p.s. jeeeesus christ
  23. Andy123
    Andy123 Member
    260
    It'd be working its nuts off producing that much power and getting pretty hot in the process. Looking forward to seeing how this setup turns out, should be mental. Good luck with getting it sorted mate.
  24. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Aye good luck Andrew, hope they get it sorted for you. Cant wait to see how it goes.
  25. Andrew@A.L.D
    3,877
    617
    3 times more power than originaly early s3 love it
  26. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    630bhp....... Thats just showing off :p
    On a side note, best of luck. How is that beast going to handle? I can only imagine an ibiza with that power would be close to suicidal.
  27. Westy
    17,443
    1,103
    You'll need to get some decent tyres on Andrew! My car is lethal in the wet with the cheap stand in tyres i've got at the moment! I can get all 4 wheels spinning if I nail it out of roundabouts :)
  28. Andrew@A.L.D
    3,877
    617
  29. s3dave
    10,110
    736
  30. Sam_
    Sam_ Down under
    3,037
    480
  31. badger5
    9,424
    1,972
    thats about the feel of it yes.
    I used to run 35psi on its previous GT35... never had a max power figure as we max'd the dyno we were using fo rmapping at the time.. >530kw @ wheels
    Mines on 24-25psi currently.. and 545bhp, so if Andrews seriously planning 30psi (which is very high-read hot!) >600bhp should be an achievable number.. mental. :D love it :D
  32. Prawn
    11,448
    3,343
    Holy **** Bill, 530kw at the wheels is 710bhp!!!
  33. jojo
    28,856
    3,516
  34. Prawn
    11,448
    3,343
    Hardly the UK's fastest S3 though is it? Alex at Storm
    built the 3.2 turbo s3 that was about 650bhp! Plus storm have done a 700bhp + 2.5 5 pot s3
  35. s3dave
    10,110
    736
    But not technically S3s with the different power-plants.. :)
  36. Andrew@A.L.D
    3,877
    617
    Im a purest and will keep the 20vt engine
    Spoke to Andy and he's looking into the problem with the pulleys
    Im making some bits for it to fit this weekend
  37. Sam_
    Sam_ Down under
    3,037
    480
    Without sounding harsh, I'd never buy that linked S3 based on the advert. 4mm wastegate sounds small too, I'm sure my vacuum hoses are larger...
    I'm sure there are more powerful 2.0 TFSI's in the UK? From what I've seen they are way more tuneable than the 1.8s?
  38. camscockle20vT
    1,740
    77
    In what way? A 2ltr tfsi lump aint going to be cheap. Bang for bucks the 20v has to be the best option.
  39. camscockle20vT
    1,740
    77
    Oh and @ bill, no wonder yams ibiza ended up in the wall at santapod :(
    You guys have brass balls.
  40. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    I think he means that if the car has a 2.0t it's more tuneable then a car with a 1.8t is.
