[How To] HBA Retrofit on 8V/MQB Platform
Module 20 coding for LED headlights and right hand drive is :-
0404010700000000010000
Is this the long coding as mine isn’t working but is displayed on the clusters when pressing the stork back .
Also what mirror have you used as I’m using the Audi A3 mirror part number 81A857511A
Reactions: Rob2k68
Yes module 20 HBA long coding
My car is a Golf R so part number 3G0 857 511 BD.
Went full circle to having this factory fit on my S3 to now retrofitting it on the R.
Sent from my iPhone using Tapatalk Pro
Been flashed a few times does anyone know if there is coding to make it react quicker and turn off the beams a fraction of a second sooner ?
Hi that’s all down to the hba camera as I’ve found some react slower than others
Reactions: Rob2k68
Is the long coding the same for a A3 8v thanks
What lights do you have and year of car ?
My pre facelift S3 with the optional LED lights was :-
04028764747464545425363E00
Hi I have a Audi A3 8V 2017 with full led headlights
Reactions: Rob2k68
Hello,
Fitted the Mirror with part no 81A857511C and followed everything on the tread twice. All i'm getting is no response from controller Any help Please....... See attached scan
Friday,12,July,2019,13:31:46:27004
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
Dealer/Shop Name: Northeast Vag
VIN: WAUZZZ8V0EA126889 License Plate: MINE
Mileage: 64582km-40129mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 42 44 52 55 5F 6C A9 BB
BC
VIN: WAUZZZ8V0EA126889 Mileage: 64582km-40129miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 0100
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 HW: 06K 907 425 A
Component: 2.0l R4 TFSI H09 0006
Revision: --H09---
Coding: 0A1D00322426010B2004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0218V0906259 001008
ROD: EV_ECM20TFS021_AU37.rod
VCID: 7DA4F0D30D77F92FA1F-8028
2 Faults Found:
17178 - Databus
U1123 00 [047] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 4
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:28
Engine speed: 798.75 /min
Normed load value: 3.9 %
Vehicle speed: 0 km/h
Coolant temperature: 92 °C
Intake air temperature: 63 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.675 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
15072 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 64582 km
Date: 2019.07.12
Time: 13:07:07
Engine speed: 922.75 /min
Normed load value: 3.5 %
Coolant temperature: 96 °C
Voltage terminal 30: 11.914 V
FRF_IMMO_SNAPSHOT_BYTE1: 20
FRF_IMMO_SNAPSHOT_BYTE2: 127
FRF_IMMO_SNAPSHOT_BYTE3: 138
FRF_IMMO_SNAPSHOT_BYTE4: 2
FRF_IMMO_SNAPSHOT_BYTE5: 0
FRF_IMMO_SNAPSHOT_BYTE6: 0
Engine: operating status: IS
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 011 R HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4311
Revision: 05852204 Serial number: TFK01401220526
Coding: 0014
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 2412E5B7CE5D68E78E1-8070
2 Faults Found:
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
21197 - Transmission Control Unit
P1701 00 [008] - Locked
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 64582 km
Date: 2019.07.12
Time: 13:07:07
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 600940000000BC
Coding: 32F193A254222A72037F070841CC694CC92A54C0E08296F7024150388608
Shop #: WSC 01214 210 12345
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BA0FECB1363F71F9FB-802E
2 Faults Found:
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 133
Date: 2019.07.12
Time: 13:04:27
16390 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 133
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:39
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000224411
Coding: 03100014000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 333016EB7BB3FF5F07B-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: BC2904E6000000000001
No fault code found.
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011401000038
Coding: 07141A46C24122F503844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 131215 041 0580
Serial number: 131218215611
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22115226
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Component: E1 - LDS MQB H05 0032
Serial number: 07 10 2013 00000066
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY133360JLN
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028338110
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO2590025/
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 B HW: 5Q0 919 298
Component: PARKHILFE PLA H11 0033
Revision: -------- Serial number: 61131332200983
Coding: 0130160051
ASAM Dataset: EV_EPHVA2CAU3700000 003015
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 3E2637DF40F12237F85-806A
1 Fault Found:
13637426 - Databus
U1123 00 [009] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 133
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:26
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R04MZ5Y
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4BC06E0B0343879F6FB-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 301 14
Component: SideSensor_Df 001 0887
Serial number: 357670000005CC097E01
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 000 301 14
Component: SideSensor_Pf 001 0887
Serial number: 3586700000041D097E0Y
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 400 401 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502A713013E4C33/
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 400 401 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502A313013E3225R
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 403 011 13
Component: FrontSensor_D 001 6149
Serial number: 3556502A11220563926U
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 712 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502BD1220564A0E7
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 712 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502BB1220563F286
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 811 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502AB1220760619U
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 10011408491165
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_010_AU37.rod
VCID: 094C940349BFD58F9D7-805C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 R HW: 8V0 920 970 R
Component: KOMBI H03 2220
Coding: 27ED080A2B9026000101EE00100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
2 Faults Found:
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 113
Mileage: 64582 km
Date: 2019.07.12
Time: 13:07:00
9634288 - Transmission Control Module
B1301 F0 [008] - Not Authorized
Freeze Frame:
Fault Priority: 1
Fault Frequency: 66
Mileage: 64582 km
Date: 2019.07.12
Time: 13:07:00
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001421310
Coding: 030100042B085A005B0002681C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FD84ADB47FB2B3FF33-806A
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 02 12 2013 D0363137
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 7846082203
1 Fault Found:
131632 - High Beam Assistant Control Module
U1070 00 [009] - No Communication
[Timeout Knoten 0x30 / 20 - Steuergerät für Fernlichtassistent]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 133
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:27
Supply voltage: Terminal 30: 12.6 V
Terminal 15: On
Address 20: High Beam Assist.
Cannot be reached
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00002.12.13
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 46D65F3F18217AF7B05-8012
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 09011406070294
Coding: 00518E205C01040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40DA49273A0554C78A9-8014
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8303
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 353428F375C7E16F29F-8060
1 Fault Found:
16130 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:26
Motor status: 01
System status: Driving mode
Supply voltage: 12.50 V
Temperature: 51.0 °C
KFC: 3F
KFA: 00 02
Environmental conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 12.63 V
uAdSensI_SwitchedKl30_xdu16: 12.64 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 31121306070359
Coding: 005186205E01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 01AE000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75B4E8F33547A16FE9F-8020
1 Fault Found:
5256745 - Rear Left Ride-Height Sensor
C1036 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 173
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:29
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 036 A HW: 8V0 035 036
Component: MU-H-LND-EU H42 0281
Serial number: A300A0E7502002
Coding: 017303010000000021111102000A00102F00022701000100DE
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 303A19E78AA5C4477A9-8064
Data medium:
Subsystem 1 - Part No SW: V03 959 800 TB HW: -----------
Component: ECE 2016/2017 --- 0153
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9DY200F1Y
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 R HW: 8V0 919 614 D
Component: ControlUnit_H H64 0766
Serial number: C1000021101300020370
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1008
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300012201000300
Shop #: WSC 86562 184 84156
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
2 Faults Found:
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 133
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:26
passive
9529428 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 133
Mileage: 64582 km
Date: 2019.07.12
Time: 13:04:26
passive
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0008
Serial number: 131212200065
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 13121304081562
Coding: 004186204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 42DE432F340946D79CD-8016
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0025
Serial number: 13121303111754
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:41, VBatt start/end: 12.9V/12.9V)-----------
Faulty control unit, not connected correctly or faulty wiring / power feed etc... basically your vehicle gateway cannot see / talk to the new module you have added.
Cheers for the reply, OK so I have checked with my Multi Meter and i'm getting conductivity on the cabling. is there away of checking the can low and can high voltage? i'm assuming the mirror is faulty.
Thanks Dan
Thanks Dan
If you have checked for continuity on the complete loom, have a solid earth and 12v then I would reverse your CAN wires. If you still have no connection then you have a faulty mirror
Reactions: T-800
Hello,
As soon as I remove the mirror the fault goes and, just say High Beam assist fault, i've checked the Voltage Low Can is .04 v and High Can is 3.4 volts so i'm assuming its the Mirror.
Hello Lads,
Ok so have it working now but the Auto dimming Mirror is not working, would this need some different coding? I have Drivers and Passenger side dimming Mirrors to. Any Ideas?
Thanks Dan
Ok so this is the fault codes I have now, Any Ideas? Remembering I have Passenger and Driver side Dimming Mirrors which are not working, whih I understand are controlled by the Main Dimming Mirror. Coding? Faulty Mirror?
Friday,12,July,2019,20:45:29:27004
www.Ross-Tech.com
Mileage: 64593km-40136mi Repair Order:
BC
VIN: WAUZZZ8V0EA126889 Mileage: 64593km-40136miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
17-Instruments -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
Revision: --H09---
Coding: 0014
Coding: 07141D46C24122F503844004B31C07A80000000000000000000000000000
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Sun Roof:
Coding: 901E00
Coding: 0130160051
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A418
Alternator:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 64593 km
Date: 2019.07.12
Time: 20:29:42
Supply voltage: Terminal 30: 13.8 V
Terminal 15: On
Address 20: High Beam Assist. (J844) Labels:* None
Part No SW: 81A 857 511 C HW: 81A 857 511 A
Component: FLA H10 0003
Revision: AA001001
Coding: 0202010000000001000000
Shop #: WSC 51339 002 104857
ASAM Dataset: EV_HighBeamAssisAU724 001007
ROD: EV_HighBeamAssisAU724.rod
VCID: 280AF187B2758C87A29-807C
4 Faults Found:
13238273 - Databus
U1121 00 [009] - Missing Message
[ECU for steering wheel electronics: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 64593 km
Date: 2019.07.12
Time: 20:29:27
Communication status of data bus 1-Brake control module: No communication
Communication status of data bus 1-Diagnostic interface for data bus: No communication
Communication status of data bus 1-Engine Control Module (ECM): No communication
Communication status of data bus 1-Vehicle Electrical System Control Module: Communications link
Communication status of data bus 1-Central ctrl. unit for comfort system: No communication
Communication status of data bus 1-Steering column electronics control module: No communication
13238274 - Databus
[Diagnostic interface for data bus (Gateway): no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 64593 km
Date: 2019.07.12
Time: 20:29:27
13238275 - Databus
[ECU for engine: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 64593 km
Date: 2019.07.12
Time: 20:29:26
13238276 - Databus
[Break-ECU: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 64593 km
Date: 2019.07.12
Time: 20:29:26
Coding: 0001
Coding: 8303
Data medium:
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 64593 km
Date: 2019.07.12
Time: 20:24:12
passive
End----------(Elapsed Time: 01:41, VBatt start/end: 13.7V/13.7V)-----------
Any Help would be great. Thanks Dan
Well you still have a communication issue with the control module / mirror. If you have checked power and cabling then it’s a pretty safe bet that your mirror is at fault.
Well, New Mirror bought and all is OK, so looks like it as a faulty Mirror. Thanks for all the reply's and help with this.
Thursday,18,July,2019,15:01:23:27004
www.Ross-Tech.com
BC
VIN: WAUZZZ8V0EA126889 Mileage: 64854km-40298miles
09-Cent. Elect. -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 8V0 857 511 HW: 8V0 857 511
Component: FLA H03 0002
Revision: AA001001
Coding: 02028764747464545425363E01
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 79ACE4C3195FC50F8D7-802C
Again Thanks Dan
Reactions: DJAlix
Hello guys
I don't knoe if you are still active on this thread but I need some help.
I own an Audi A3 8V (2013) with Bi-Xenon headlight, no Light/Rain sensor (only humidity) and normal rear view mirror (with no wires).
I've bought the Rain/Light sensor and the switch with AUTO, everything works perfectely but I wanted to retrofit HBA too (remember, normal mirror, no wires with conector in the headliner beside the one for humidity sensor, now Light/Rain sensor) and I've bought the wire kit that goes into the mirror (5 wires: 1 mass (ground), 1 red-white (says it goes into PIN 1 for OBD2 port) 1 white (goes into dome light) and 2 ones for CAN High and Low).
My car comes equiped with CAN High so no problems there.
I managed to connect the CAN wires to the footwell connector and without any changes into VCDS/OBD11 when I push the stalk there is a message (High Beam Assist System Fault) meaning there is curent passing through the wires. But it doesn't work, neither is auto dimming for the mirror itself.
Trying to activate module 20 in OBD11 for High Beam Assist doesn't do anything, it says that control unti doesn't respond (like not installed I guess)
What did I do wrong? What could it be the problem?
Thank you guys
Hello guys
Thank you guys
Hi firstly do you definitely have the high can also what mirror are you using as the standard mirror isn’t comparable for hba as it’s most likely be down to the mirror if all wiring is correct think it’s pin 17 and 19 on the can gateway can high/low and power from pin 1 on the diagnostic socket .
Reactions: Alin Marin
HY.
i want to make HBA retrofit on my Audi A5 Sportback. I have the mirror, CAN Gateway is extended. i check that. If i have Lane Assist, i must use that 2 cable to CAN or can i use cable from lane assist?
Does anyone know if the facelift 81A857511A HBA mirror will work with a pre facelift 2015 s3? Many thanks.
Don't see why not although it's an expensive buy if it doesn't. I have a pre facelift one on ebay if you want to try that
I'll pm you as dont know if posting links are allowed
When you say pre facelift you do mean 8v yes ? If not I think you'd have to upgrade you central electrics module
Hello guys
Thank you guys
hello, I also have an a3 prefacelift + zenon + 8s0857511c have you found the correct coding for module 20? everyone seems to have leds :(
Hi,
I have a MY2015 PFL with LED auto headlights, I have coded as required and installed the wiring for the HBA camera
The HBA camera I have managed to find is 81A857511G which I have found out is actually a camera for Matrix LED's
I have the little A inside a headlamp on my DIS showing the Main Beam Assist is active without any errors showing on the DIS
When I check my 19 CAN gateway (MQB HIGH) for faults I have a fault "Additional Installations Detected" which i'm trying to figure out why this is appearing
The High Beam Assist 20 unit is coded to have LED headlights
I have coded the control units using my old 12.12 VCDS clone (shame :sadlike:) I have a HEX-V2 Genuine on order to arrive shortly as I cannot view the long coding helper with the cable I have on 20 High Beam Assist unit so im wondering if there is an incorrect coding with it being for Matrix LED camera and I need to code it to just use the camera for High Beam Assist.
Can anyone help or guide me?
Many thanks, Rich.
Hi,
Many thanks, Rich.
You have told us what coding you completed via your cloned VCDS so hard to assist…
I will wait for my V2 to arrive then post up an autoscan once I’ve checked over and redone the coding
Post up anyway.
Additional Installations Detected = something has been installed to the CAN network and not added to the gateway installation list.
Reactions: Mr.P
VCDS Version: Release 12.12.0
Data version: 20130910
Sunday,01,January,2023,00:08:31:62939
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 42 44 52 55 5F
VIN: WAUZZZ8VXFA001982
13-Auto Dist. Reg -- Status: OK 0000
20-High Beam Assist. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
Address 01: Engine (J623-CUNA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 ER HW: 04L 907 309 A
Component: R4 2.0l TDI H22 9972
Revision: 81H22---
Coding: 021D0032036701082000
Shop #: WSC 10539 006 1048576
ASAM Dataset: EV_ECM20TDI01104L906021ER 004013
ROD: EV_ECM20TDI01104L906021ER.rod
VCID: 79F90B6FF82C89D6D3D-802C
Readiness: 0 0 0 0 1
Part No SW: 0D9 300 013 A HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 5232
Revision: 05852204 Serial number: TFK01404220511
Coding: 0014
Shop #: WSC 04742 780 00200
VCID: 152127DFF4744DB6575-8040
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 61264000000181
Coding: 12F18AA234200A6D0180070841C52948512C5080E08294F4F86150788608
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 4683B093F952362EEEF-8013
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Revision: 20026000 Serial number: 00000000323169
Coding: 03100104002000011000000000001100
VCID: 3365F9479AC0B386591-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011413000812
Coding: 07041D46C24106FD03844004F31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 800FE68B1BF6581E143-80D5
Component: WWS370 140426 041 0580
Serial number: 140430150424
Coding: 0A47F7
Serial number: 22635959
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Serial number: 06 01 2014 00000249
Serial number: 000000000ZY140974SJB
Serial number: 00000000000059599269
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 G HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0051
Revision: -------- Serial number: 39431407801108
Coding: 0130061051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_AU37.rod
VCID: 4385A987CA600306C91-8016
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H04 0303
Serial number: 12051476510248
Coding: 003C1301FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001015
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 387FCE6B83A650DE6C3-806D
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Serial number: 003M2R06RXWN
VCID: 4B9581A7E230CB46311-801E
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 505 14
Serial number: 357670000008BA149F00
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 505 14
Serial number: 3586700000046A149F0Z
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 805 14
Serial number: 3516502C5156E9F6420F
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 805 14
Serial number: 3526502C7156E9F3F2D$
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 004 14
Serial number: 3556502B51524DC4D24G
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 402 504 14
Serial number: 2286502BD1529DF4615O
Coding: 2D2D2D
Pedestrian protection crash sensor; passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 402 504 14
Serial number: 2296502BF1529DF2328Q
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 402 504 14
Serial number: 2306502B71529DF3A24E
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 BR HW: 5Q0 953 549 C
Revision: -------- Serial number: 10051404401058
Coding: E418
ROD: EV_SMLSKLOMQB.rod
VCID: 8B15C1A722B00B46711-80DE
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 971 H HW: 8V0 920 971 H
Component: KOMBI H02 4290
Coding: 278508082F9026000180EA001000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 428BAC83D57A0A0EC27-8017
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0001944738
Coding: 030100040F0876005B0002581C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_AU37.rod
Generator:
Multifunction unit control module:
Serial number: 12 05 2014 F0002938
Serial number: 9341023403
1 Fault Found:
66304 - Databus
U1124 00 [009] - Additional Installations Detected
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 81A 857 511 G HW: 81A 857 511 A
Component: FLA H10 0008
Revision: AA001001
Coding: 0404010700000100010000
ASAM Dataset: EV_HighBeamAssisMXBAU33X 001003
ROD: N/A
VCID: 2C57E23B47FEEC7E18B-8079
No ASAM data for: "EV_HighBeamAssisMXBAU33X" (AU37)
1 Fault Found:
13238282 - ROD - Unknown Error Code
- 00 [009]
Address 42: Door Elect, Driver (J386) Labels: None
Serial number: 02051403110525
Coding: 001C8E204001040000001003
VCID: 408FA68BDB76181ED43-8015
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8303
ROD: EV_SteerAssisMQB.rod
VCID: 4189A38FD07C1116DBD-8014
Address 52: Door Elect, Pass. (J387) Labels: None
Serial number: 03051401100996
Coding: 001C86204001040000001003
VCID: 3F8DA577A68867E6AD9-806A
Address 55: Xenon Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 B HW: 7P6 907 357 B
Component: AFS-ECU H01 0040
Coding: 01AE00002B230200
ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
ROD: EV_HeadlRegulLEDAFSMQB.rod
VCID: 3E73D873A1826EEEA6F-806B
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo li. H07 7530
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo re. H07 7530
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7000
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7000
Coding: E00100
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 018 B HW: 8V0 035 020
Component: MU-H-ND-EU H43 0415
Serial number: A305B0EB001863
Coding: 01730301FF0A000021111101000A00002F00010701000100DE
VCID: 3169F34F60DC81962BD-8064
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 PS HW: -----------
Component: ECE 2014/2015 --- 0086
Seat Adjustment Driver Side:
Component: DU High H49 0014
Serial number: AUZ8Z9EY2011S4
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 K HW: 8V0 919 614 K
Component: ControlUnit_H H81 0816
Serial number: C1000019121400010229
Door Electronics Rear Left:
Component: Gracenote --- 1009
End ---------------------------------------------------------------------
Post up anyway.
Hi DJAlix,
I have installed genuine VCDS now and managed to read the fault codes from the mirror correctly now, It looks like the mirror is trying to find the control unit for the matrix headlights, is there anyway I can code it so it is not looking for it and causing a fault?
Many thanks, Richard.
Hi DJAlix,
Hi DJAlix,
To be honest I would need to connect to the car and see what coding is available. Long time since I have done a HBA retrofit.
I have changed the setting to link into the can-bus through the adaptions setting so now it is using the can-gateway to communicate with the different control units on my a3 8v PFL where before it was connected through single wire?, the only control unit with no communication is the headlight control unit which I would imagine it’s trying to talk to the matrix-beam control units which my car does not have, @DJAlix can you remote in on my VCDS?
IMG 1018
Managed to sort this, I just bought the mirror with the HBA camera in instead of the Matrix camera Mirror…
Is there anyway to make the camera react quicker or more sensitive to oncoming light? Finding when driving the HBA activates in complete darkness but then if someone is driving towards me it doesn’t always turn off?
D
5K
