- Joined
- Jun 19, 2009
- Messages
- 3,883
- Reaction score
- 619
- Points
- 113
- Location
- Leeds
- Website
- www.aldevelopments.com
Fitted the Wideband ecu and did everything was needed, we fitted a RS4 maf in the end and had to cut wire 63? to the ecu to stop fans kicking in all the time
has some problems with the immobilizer to start with then bang its started up, took some time to get the idle right and fueling too, Paul did a run with just 10psi and it made an extra 20bhp from the inlet i made from last time it ran 10psi on the narrow band.
We were about to turn up the boost when it sounded like one of the pulleys bearing for the timing belt started to make a loud squeal and at that time we said we would just end it then at 8 pm
Not as i planned but i'm glad its not the engine making that noise and its just some sort of a bearing in the pulleys?
So Andy Speck will be having a look at it tomorrow to see what the noise was
Paul did say it was looking good and will do 500bhp, Paul was very nice to give me a lift home in his 511bhp R26 megane !!! and i must say that that thing blood shifts !!! I am going to look forward to having 500bhp for myself
Paul also recommend fitting a boost controller so i'm not running 30psi and 500bhp all the time
