Volks AutosBadger5
Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 121 to 160 of 439
Like Tree15Likes
Thread: Sandips (strange) build thread
  1. #121
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    Are you going to query superchips ?
  3. #122
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by voorhees View Post
    Nah, i rang them a while back to query my chip and the response i got from them was very poor, i would strongly urge anyone who has got a Superchips map to check their fueling
  4. #123
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by SiGainey View Post
    Chipwizards are going to be my point of call when I get a remap. Not the cheapest but one of the best
    True! Wayne's also a Revo dealer and could of quite easily put stage 2 on, glad he checked everything over and is starting from scratch, plenty more yet to come, 6/7 more precious psi's left to play with
  5. #124
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    Its not the best service by the sounds of it by superchips
  6. #125
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Yeah and possibly the worse map for a 1.8t lol
  7. #126
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Good luck with it all mate, hope you sort your power problems out.
    Car looked the nuts at elsecar!!
    Audi S3 1.9 GT30....
    ....that is all
  8. #127
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by MUSH View Post
    Thanks Mush, didn't know your were at Elsecar lol I reckon once the fuel pump and 4bar fpr are in i'll be good to go, i'll probably end up maxing out the injectors lol
    Before Wayne started the map he gave the car a hard run on the dyno to see what kinda egts i was getting, the exhaust manifold was glowing like the sun but after a few goes the hottest we could get the egt's was 880oC. Should it get hotter??
  9. #128
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    IIRC k04s can push right up to 900-950 C when pushed hard to get to their 260bhp levels. Maybe yours arent that bad as yours allows better flow, or then it may simply be because your not pushing big power levels yet. Either way 880 C is relatively safe atm
    ....that is all
  10. #129
    RIP S3dave
    May 2004
    nr Glos
    7,141
    Quote Originally Posted by sandip View Post
    on par with some of the worst maps with that boost only mod..
    see it all too often on the no name cheaper maps..... no names no pack drill... they know who they are
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  11. #130
    RIP S3dave
    May 2004
    nr Glos
    7,141
    if its not running much more than a bar of boost the egt's would'nt (should'nt) get to the 920 egt protection trip.. but that is also dependant on the loads applied by the dyno. hold it loaded and it will. what gear does wayne test in.. (I think its 3rd from what I read others use... which is not a lot of load on acceleration runs, so not as hot as it would be in say 6th wot from 3krpm for example)
    std fueling on 0.95 under wot will cause higher egt's and in turn higher cf's than more appropriate fueling.
    sounds like you will finally get a map which suits the car.
    bill@badger5.co.uk
  12. #131
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Yes Bill, finally getting a map that suits the car
    All the mapping was done in 6th gear and from what i know he tried his best on the standard map to get egt as hot as possible, he was trying to get it to trip to dump fuel but highest temp we saw was 880oC. Will be going back as soon as the new pump is in. Got a feeling that i'm going to end up maxing out the injectors
  13. #132
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    ...Time for a new fuel pump and 4bar fpr....
    New fuel pump fine but no point in a 4bar FPR tbh... have you checked the current FPR to see if its blocked or owt? whats block 032 saying?
    <tuffty/>
  14. #133
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Yeah i checked the FPR a few days ago and it was clean, no blockages or anything, i haven't logged 032 myself but Wayne was keeping it around 12.5 but at 16psi on boost at around 5k it started losing fuel pressure. Got the fuel pump today, ECP gave me the wrong one first, think it was for an A3, took mine off and the bloody thing was totally different, rang them up, gave them the part number and luckily they had one in stock.
    Does this look right??
  15. #134
    Aug 2007
    40
    Hi Sandip,
    That's the right pump dude, just replaced mine and it made a big difference.
    Regards
    James
  16. #135
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by quinnj2 View Post
    Hi Sandip,
    Regards
    James
    Phew that's a relief, did you put it in yourself?? Looked a bit fiddly when i opened it up today lol
  17. #136
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quick update, the new pump was put in on Saturday, seems a lot quieter than the old one!
    Also removed the oil breather pipe going into the t.i.p and it's now vented to atmosphere, i've routed it underneath the car, so far i've had no nasty oily odours coming into the cabin. Took it out for a blast after doing this yesterday and the red chargepipe to turbo popped off once again, it's been a pain since the day i bought it (Forge hose), so the oem hose went back on, will see how long this lasts......
    Will try and post some pictures of the breather later
  18. #137
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    I'd like to see where you've vented the breather mate. I looked into venting mine under the car cut didn't like the thought of the hose and breather going down close to the drive shaft.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  19. #138
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by Westle View Post
    I looked at putting it down near the driveshaft but put me off for the same reason, mine's actually near the driverside intercooler, will post some photo's up later Westle
  20. #139
    RIP S3dave
    May 2004
    nr Glos
    7,141
    what clips are being used to hold it?
    they can sometimes be too long I have seen, and unless pushed over the turbo's outlet will sit too tall, which when the chaerge pipe is clamped down, will kink the hose on the bend, reducing its internal surface area=bad
    bill@badger5.co.uk
  21. #140
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    will see how the car pulls on wednesday sandip im aiming for 240bhp so can judge of yours how much difference it will make think i will be going to see wayne next month or month after to look at a map
  22. #141
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    It's buggered beyond repair Bill, i've tried a few different type of clips but they kept slipping off, it's the turbo end what was giving me the bother because a jubilee had dug into the hose in a funny way and everytime i tried to tighten it up it kept dropping into the groove
  23. #142
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by paul syverson View Post
    I'll be the last one in the convoy lol
  24. #143
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    i can see me and phil beeing pulled over especially if there are bikes about lol soon as phil goes im off behind him like a flying bee
    Rob_k likes this.
  25. #144
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    this convoy will either be good and organsied or a mess with people flying down the motorway chasing one another.
    as its a l8 meet up at stockport before we head down to buxton i can see it beeing a fly down convoy
  26. #145
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Did a little video of my exhaust too, might post that later.........
    Inertiauk likes this.
  27. #146
    Westy's Avatar
    Dec 2008
    17,264
    cheers for the pics mate.
    Do you not have a catch can then, you just vent the normal system to atmosphere instead of back to the TIP?
    S3 Build Thread
  28. #147
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Bunged up the TIP and vented straight to atmosphere, going to have to make a catch can though as it get a little smokey when i'm stationary lol
  29. #148
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I've put the breather hose back into the t.i.p today, defo need a catch can when it comes to oil breathers.....
    Whilst doing this i noticed that my vac line was leaking on the FPR so i've changed that so it has it own line that is now connected to the nipple underneath the inlet manifold, once the line was sorted a tightened up some of the pcv connections under the mani and gave things a quick wipe....
    Now this is all i have done but my car has now got more of a chatter, my car has never had chatter in the 5yrs of me owning it
  30. #149
    shanejess
    chatter, did someone say chatter, sell up and hide under you bed sandip lol.
  31. #150
    Westy's Avatar
    Dec 2008
    17,264
    Mate your car is weird.
    S3 Build Thread
  32. #151
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Ahhh well i'll try a sort it though, got another dv i can try
  33. #152
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by shanejess View Post
    If your misses heard my car coming down the road she'd start getting tea ready because it sounds like yours
  34. #153
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Will be doing some vag com logs on Friday night (10/6/11)
    Mutantfatcat (Lee) will be letting us use his Vag Com like we did last time when we met near Awesome, i'll be logging mine anyway but if anybody wants to do get some blocks checked and do some logs then you're more than welcome to pop by
  35. #154
    Westy's Avatar
    Dec 2008
    17,264
    Good luck mate, hope you get to the bottom of some of your strange running issues.
    S3 Build Thread
  36. #155
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Thanks bud, i gave it some stick lastnight and no hoses popped off and the chatter issue is the dv i think, at full boost (16psi) it does the normal woosh but flutters on part throttle, i'll try another dv to see what difference if makes
    I really want to see what my a/f ratio is now at the top end
  37. #156
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Where and when you doing the logs Sandip? I may pop down and see ya.
    My car has an odd bog down of power as I accelerate after changing into second from time to time.
    Kristian
    No longer an Audi driver...
  38. #157
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by Wizza View Post
    It'll be at Awesome for around 19:00ish, No harm in doing some logs bud but i reckon yours won't flag up any major concerns
  39. #158
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Will be there dude :D will drop you a text during tomorrow just to double check.
    Kristian
  40. #159
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Photographs that were taken by Mutantfatcat on Friday night
  41. #160
    shanejess
    whos that handsome swine in the brown poloshirt, that black edition 8p ibis white is nearly as cool
Tags for this Thread
