can anyone help with these codes please upgraded from halogen to xenon in a 2010 a4 b8 im at a loose end here Address 09: Cent. Elect. Labels: 8K0-907-063.clb Control Module Part Number: 8K0 907 063 K HW: 8K0 907 063 K Component and/or Version: BCM1 1.0 H25 0380 Software Coding: 690040B10034A7010001000000005F5F001D020804000141000000 Work Shop Code: WSC 06325 123 12345 VCID: 372B2EB56E43EEE3A21-8062 9 Faults Found: 03351 - Bulb for DRL and Marker Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 20 Reset counter: 168 Mileage: 179390 km Time Indication: 0 Date: 2020.07.01 Time: 16:49:00 03354 - Bulb for DRL and Marker Light; Right 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 168 Mileage: 179390 km Time Indication: 0 Date: 2020.07.01 Time: 17:04:00 00978 - Lamp for Low Beam; Left (M29) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 206 Mileage: 179397 km Time Indication: 0 Date: 2020.07.02 Time: 13:46:00 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 206 Mileage: 179397 km Time Indication: 0 Date: 2020.07.02 Time: 13:46:00 01495 - Bulb for High-Beams; Left (M30) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 165 Mileage: 179390 km Time Indication: 0 Date: 2020.07.01 Time: 20:08:00 01499 - Bulb for High-Beams; Right (M32) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 165 Mileage: 179390 km Time Indication: 0 Date: 2020.07.01 Time: 20:08:00 02745 - Bulb for Daytime Running Light; Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 165 Mileage: 179390 km Time Indication: 0 Date: 2020.07.01 Time: 16:49:00 02746 - Bulb for Daytime Running Light; Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 165 Mileage: 179390 km Time Indication: 0 Date: 2020.07.01 Time: 17:04:00 00910 - Indicator Lamp for Emergency Flashers (K6) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 205 Mileage: 179336 km Time Indication: 0 Date: 2009.06.26
You're getting a distinct lack of help on here Lee, you need to join some more groups and post the same questions. VCDS Users UK and Audizine may be good starting points, Audizine is mainly American but I think may have a specialist VCDS section where you might find someone who has done the same conversion and experienced similar issues getting the DRL's to work. Trups at EM Tuning has done loads of work on these type of headlights too, he may be able offer some advice. Have you got the D3S headlight Bulbs and indicators on both sides working ok?
Thanks but headlights and indicators are working fine also ive joined them groups m8 no one seems to wanna give me some answers but really appreciate the replies m8 thanks again
Check this thread out to see if it's any help Lee https://www.audiworld.com/forums/a4...elp-vag-com-coding-bi-xenon-headlamp-2773132/
Join this group, have a search around and if you cant find anything specific to your issue, post your question https://www.audiworld.com/forums/a4-b8-platform-discussion-128/
Thanks Eldeano2 i will give these codes a try its got my head farting lol not been able to sort it out as im new to all this once again thanks for trying to help me i appreciate it
Did you rewire anything, did you check if positions of the wiring for halogens in the back were different to bixenons, coding correct? These things are your 1st checks, she fitting other OEM headlights, there are at times wire modifications needed for factory fit or you get errors of this nature, it would be my 1st checks anyway. Aftermarket adapter sets sometimes just fool the system to make it work with halogen wiring & thus errors remain, even if lights work. Check all this then report back.
Then you need to check the bixenon & DRL wiring & compare with halogen, some maybe the same, but it has to be done 1st, as the position of wires on the module maybe different.
