Window Regulator
aiwa_yamaha
Hi people
Fitted a new Window Regulator today and it goes down fine but going back up goes real slow. Anyone know why?
Take the door card off again and losen the 2 screws which hold the runners in place at the bottom of the door, then run the window down then up again and tighten ! That should hopefully.help
Are the two screws at the bottom or you mean the two screws that hold the regulator to the glass?
Not the ones on the glass ! The two on the bottom of the door frame itself there's one beside the speaker and one behind where the side pocket would sit !
This helped on mine when I had the same problem
Yeah i know now. Just clearing that up. Yeah i can see what you mean now. I think i have pulled it too tight so the angle is wrong with the window going up. Thanks a lot for that
