This is a good question
@TeaMonsta - ceramic coated wheels shouldn't need an aggressive acid or alkaline based wheel cleaner, the ceramic coating should protect your wheels from bonded contaminants (i.e. brake dust) fixing to your wheels - any fall-out should wash off pretty easily. This is one of the main benefits of applying a quartz based coating. HOWEVER, this is a question I've been wrestling with myself. I have exactly the same wheels as you, and I'm planning to ceramic coat them (wheels off job) with G-techniq C5 in the next few weeks...
I am paranoid about the diamond cut faces of my wheels (I've had DC wheels before, and experienced the dreaded 'white-worm' when moisture gets behind the laquer) - to the extent that I don't jet-wash my wheels, and they get gently cleaned (barrels and all) every week (sometimes more in winter when there's salt on the roads - very OCD, I know).
Up until now, I've happily used Bilt Hamber Auto Wheels as a dedicated 'bleeding' wheel fall-out remover (not every wash, but once a fortnight) DILUTED 50/50 with water). BHAW isn't a harsh PH extreme acid or alkaline cleaner (like Wonder Wheels for example) - it is marketed as a PH 'neutralised' wheel cleaner, and one I've deemed fit to clean my DC alloys safely for the last year, with no ill effects. So by my logic, it should be ok to use on ceramic coated wheels. I find it useful (diluted) as I clean my wheels at the end of the wash (using what's left in my wash bucket), and it adds some much needed suds to the process.
So, that's the long story, the short-version is I'm hoping to still use BHAW as a diluted wheel cleaner, once a fortnight, after I've c-coated my wheels. Unless anyone one here recommends otherwise? So, I've answered your question by asking a question, which might not be helpful, but hoping others will chip in
