Hi there Audi fans. I have A4 B8.5 2012 FL (my avatar) .Headlights are xenon. I have strange problem. When I exit the car with key and leave light switch to "parking" mode., only rear taillights work. Front leds(drls) are off. With ignition or when car is running,when set to 0, drls work fine at 100% brightness, when on parking mode drls are at 28% so they work fine too, and wiring is also fine.(dont have auto mode but will soon) .I have vcds and Obdeleven. Tried to search everywhere on forum and google but no luck. Cant find proper coding or adaptation.Can this be light switch- related problem? I bought used car like that. This isnt big deal for me, I can live with that, but im so affraid because Im retrofitting light sensor and switch very soon so Follow me home/Leaving home function may not work properly if I choose "ch/lh via fog lights and parking light"
And yes,in obdeleven/vcds
Central Electronics 9,
long coding 7
Byte 9
bit 0 is set to 1 for "parking mode on"
So no luck. Please help if you have any idea, thank you so much.
long coding 7
Byte 9
