Washer fluid leak!?
J moorr
Milton keynes
hi,
I’ve just purchased a stunning 2014 A5 cabriolet and have just found out it’s leaking washer fluid from somewhere?? It seems to be bottom end, passengers side near the wheel. Does anyone have any experiences in this type of leak and obviously some advice.
J
Isn't that a B8? Also there is a drain for the climate around that area so make sure it isn't that.
Reactions: J moorr
I topped up the washer fluid bottle 5 days ago and it Aske to be topped up again? There was no way I’ve used all of the washer fluid. So I’m thinking the leak MUST be that??
Reactions: cuke2u
Well now you've givem more infomation but as stated, you need to refer to the b8 forum. I don't know if the bottle is in the same place as the b9..
