Friday,01,September,2017,10:28:54:40311
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ4G6DN029419 License Plate:
Mileage: 58877km-36584mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
5F 62 6C 72 A9 C0
VIN: WAUZZZ4G6DN029419 Mileage: 58877km-36584miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 A HW: 4G0 907 589
Component: 3.0BTD EDC17 H21 0004
Revision: 57H21---
Coding: 0A2A4012052601020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30BTD0114G0907589A 001005
ROD: EV_ECM30BTD0114G0907589A.rod
VCID: 326D412765B216D64C-8066
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AB HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1003
Revision: --H16---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 6ED59557B10A723668-803A
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 49A7870192E5E180DB00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 36657D3789DA0AF660-8062
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CP HW: 4H0 907 064 CP
Component: BCM2 2.0 H32 0421
Revision: 00002001
Coding: 05B82F46000000000000
VCID: 79FFB60BF044258ECD-802C
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2312000091508010
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
Component: KLIMA 2 ZONEN H11 0070
Serial number: 05071200110355
Coding: 3621000829
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 60C9FB6F7BDED446EA-8034
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001363072
Coding: 2600A01040349FE0018100C380001D0C4F9DC30827090201000004606100
VCID: 6ED59557B90A723668-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120606 H36 0080
Serial number: 120613141204
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20379931
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 27 06 2012 00001494
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 8138C836000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061218200484
Coding: A8C306
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77FBB033CE5033FEBB-8022
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG0098V00
Coding: 30323436313330303537554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40511DEDAC0K$
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405T1EVLE6P3E
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB400A4UHL6CPSD
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB400A4UHL6QHF7
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400E4UI5EKIA8
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400E4UI5ENOPX
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120708000173
Coding: 000034
VCID: 30694B2F63BE24C63A-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 983 C HW: 4G8 920 983 C
Component: TDieGb H79 0515
Revision: 28460207 Serial number: 658300612596019
Coding: 23A708000B412600010000
Shop #: WSC 40161 002 104857
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 35677A3B94DC01EE69-8060
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000595629
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001013
ROD: EV_GatewPkoUDS_001.rod
VCID: 70E98B2FAB3E64C67A-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790722788
Voltage stabilizer:
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000033433895
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77FBB033C65033FEBB-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H02 0053
Revision: -------- Serial number: EJ1BPA72006AYA
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
VCID: 336344239AA81FDE47-8066
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0506
Coding: 011C16005E01620002080002
VCID: 479B00F3F630837E0B-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0001620677
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0179248061
Coding: 011B0E2200B90085832008040003030F0000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1705100V
Coding: 901E00
Subsystem 4 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84274190
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0506
VCID: 46850DF7F13A9A76F0-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000394106
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU57.rod
VCID: 2B535C434298471E0F-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 120704-0001-046
Coding: 1121A6101000A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2C515F5F4796402606-8078
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109G 0C7570518
Coding: 010103020100000001
VCID: 2D57525B748C492E11-8078
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 Q HW: 4G0 035 670 H
Component: H-BNT-EU H49 1034
Revision: -------- Serial number: 190GZ0C7511538
Coding: 050101000003E1EF45808B3E00000003000001000000000000
VCID: 316F4E2B68B42DCE35-8064
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC9402109$
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LG4000SN
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0506
Coding: 010814004001620002080002
VCID: 499F06CBE024750E1D-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J25G8V3
Coding: 1080004
VCID: 2645AD77917A7A76D0-8072
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0506
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 120619200624
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0004
Serial number: 120613201812
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS_VW12.rod
VCID: 2441B77F2F468866CE-8070
End-------------------------(Elapsed Time: 05:13)--------------------------
