Hi My clutch is on its way out. So im going the route of smf. the ttv flywheel is the way im going. Does any one know which clutch plate will fit? [h=1]Andrew@A.L.D which clutch kit do you run with this flywheel?[/h]Any info greatly appreciated
A little snatchy, very light and easy to use. Overkill for most people on here. Don't forget that Welly ran a standard clutch for a long time with 400+ bhp
So if i wanted to run your setup id need the above flywheel new release bearing 4 paddle clutch standard pressure plate that correct? id rather over spec my car than under spec it, plus i drive like ive stole it, i get all 4 wheels to lite up in my standard map, although the car is far from standard lol.
