thermostat
do a search theres diagrams and all sorts on here!
but its in the engine block behind the alternator follow the bottom hose from the rad
It is behind the alternator bit fiddly to get to though, i have just replaced mine recently, took about 30 mins. You need to take the top cover off then I removed the wiring that was in the way, undone the inter cooler pipe moved out of the way then removed the plastic water pipe that bolts to the block by 2 x 5mm Allen keys, the thermostat is locked into the plastic so it won't fall out when you remove it from the block by turning it into place, hope this helps
689
609
13
6K
539
