Temp sensor.
Jxly
Finally got my new flywheel and clutch fitted, car is running great. Changed from dmf to smf. Anyway, the temp gauge doesn't move for about half an hour of driving, my guess is temp sensor. If it was thermostat it wouldn't move at all? Heaters work perfectly fine. Car seems to be using a lot of fuel too. Is the temp sensor easy enough to get to and replace?
2001 A3 8L 1.8t quattro sport. (ARY)
Yes to both. Hardest bit is getting the clips off :)
Sent from my XT1572 using Tapatalk
Reactions: Jxly
Thanks Fanta, going to try pick one up today, if not I'll order one in. 10-15 min job?
Is this what I'm after?
That's the one dude.. So info on web about changing it so would definitely a search bud
It's pretty easy..you can do it no problem
Reactions: Jxly
Don't get that cheap fake one, you're looking for the green one.. Hang on link coming.
Reactions: Jxly
Part number 059919501A
Usually just over a tenner.. Don't buy the cheap fake ones as they will play up and you'll have new problems.
864
20
SDO
15
