Hi,
I have a early 2009 S3 and it has what I believe to be standard fit rear parking sensors, However the volume doesn't adjust when reversing (goes quieter) is this normal or should it adjust..? Also no distance display or anything comes up on the DIS or through the head unit again is this normal or should it..?
It's just literally a beeping warning which changes pitch the closer you get to an object...
Also does anyone have or had issue's with the standard fit Bluetooth..?
Mine has a mind of it's own and is ****, Random phone calls appearing through the head unit giving me the option to answer or decline etc either though on my phone no one is calling, The first person in my contacts often also appears in the DIS as if your receiving a call of them but again my phone is locked with nothing going on....
Thanks for your help
