Sliding rail guide replacement
CliffA4
Member
Blenheim QLD
Okay I had a passenger try move my front seat forward and a piece of yellow rubber fell out and they had to hold on every time the boost came on because the seat would slide back haha, apparently it's the seat guide. How do I replace it? I'm going to order the parts, do I need new clips for it too or just the perished rubber guide part? Thankyou.
Urmmm that's a new one on me, then again it's a B5.
That guide falling out would not make the seat go back., they are there for side to side movement and there are 2 of them. Sounds like something has come lose or broken.
Yeah I was also thinking with my COVID head, I've stripped & rebuilt quite a few seats now & the rail locator system to hold in a position is by the raising & lowering of a stud so to speak that holds it in place, that part just looks like a bush of sorts
Yeah, at first the seat wouldn't lock back in and just kept moving but I pulled the handle up to lock it in place but now it won't slide.
Post a few pictures, very difficult to say what is wrong
Having recently removed my seats and butchered up a set of frames to fit buckets, I had hoped to be able to answer this. But not sure I understand what’s happened, photos definitely needed!
The seat is kept in place by a pin which slots through a hole in a central bar. When you lift the lever at the front of the seat, the pin is pulled out of the bar which allows forward and backward movement. When you release the lever, the pin finds the nearest hole, slots back in, and the seat is locked.
Tension is kept on the lever by a very small spring at the rear of the seat, you can just about make it out in this photo. If this has snapped or come loose, the pin would not be forced back in once you’d released the lever, meaning the seat would continue to slide. I’m not sure if just pushing down on the lever would return the pin to the lock position in this scenario.
Just as a side note you can’t see the pin referred to above in the photo below as the pin section is found attached to the car beneath the seat. What you can see is the spring and central bar with holes in it. Very hard to explain in writing I’m afraid.
Alternatively, it could just be that your rails need greased. Mine were extremely stiff when I took the seats out which made the job a little tricky, took some serious effort to slide them back far enough to get them out.
Reactions: CliffA4
This is all I can see. You can just see the guide rubber on the drivers side but I can't see where it goes on the passenger side. What are these clips that come with the guide rubbers?
I
imported_VaulterTim
I
