does anyone know a working code for this, ive done a search and tried all the codes ive found but nowt works.
here is a autoscan of my car.
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
www.Ross-Tech.com
Tuesday,28,April,2015,16:32:43:10266
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 77
VIN: edited out. Mileage: 101480km-63056miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H8FNQ09T
Coding: 0103000C180F0160
Shop #: WSC 00191 264 15243
VCID: 72EBE7556D873BB168B-8027
1 Fault Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 101489 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 15.0°C
Temperature: 17.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.065 V
Readiness: 0010 0000
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 16428012092700FC680E01E5901B00813800
Shop #: WSC 06314 000 00000
VCID: 75E1DC49DCE92C894D9-8020
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 101489 km
Time Indication: 0
Date: 2015.04.28
Time: 16:23:01
Freeze Frame:
Count: 2
Count: 2
Count: 13056
Count: 8193
Count: 43776
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000250 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73E5E251129D32B963D-8026
No fault code found.
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008972258
Coding: 91AE0F07A0141380EF00000A4F00000000084E0564060003002000000000
Shop #: WSC 06314 123 08192
VCID: 489F65BD3B9BE161E6F-801D
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 499960B9E8911869F91-801C
Crash sensor for side airbag; driver side:
Serial number: 34928RB4000044B7CC2Y
Crash sensor for side airbag; front passenger side:
Serial number: 35028RB4000044AC437I
Crash sensor for side airbag; rear; driver side:
Serial number: 35128RB4000044B7CC3S
Crash sensor for side airbag; rear; passenger side:
Serial number: 35228RB400003FE0185M
Crash sensor for front airbag; driver side:
Serial number: 35547RB4000046464D7O
Crash sensor for front airbag; front passenger side:
Serial number: 35647RB400004646516D
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 4189789918A1D029211-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 D HW: 8P0 920 982 D
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2248H006000549
Coding: 0005428
Shop #: WSC 11305 000 1048576
VCID: 3A7B0F75757783F160B-806F
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K089250093
Coding: E9831F060006020101
VCID: 35611C495C696C898D9-8060
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 4385729102BDC23933D-8016
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H8FNQ09T
Shop #: WSC 00006 210 81331
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000564
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 234 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5B3F3585D7337110B-807F
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D850548DAC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000564
VCID: 4487718D07B3C5010A7-8011
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000013
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 195 M HW: 8P0 035 195 M
Component: R Symphony2+ H05 0270
Revision: 00H05000 Serial number: AUZ1Z4H7177782
Coding: 0710201
VCID: 3C77096D7F43BDC1727-8069
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005040336
Coding: 0001222
VCID: 46836B85318FF711143-8013
End-------------------------(Elapsed Time: 01:52)--------------------------
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 101489 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 15.0°C
Temperature: 17.0°C
Voltage: 12.065 V
Revision: 00H35001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 101489 km
Time Indication: 0
Date: 2015.04.28
Time: 16:23:01
Freeze Frame:
Count: 2
Count: 2
Count: 13056
Count: 8193
Count: 43776
Count: 0
Count: 0
Count: 0
Coding: 00056595
Shop #: WSC 06314
Coding: 0004042
Coding: 0005428
Coding: 0000005
Coding: 0000564
Revision: 00H15000
Coding: 0000564
Coding: 0000013
Coding: 0710201
Coding: 0001222
