Scan code errors - S4 cabby - just a few :-[
AdamsDad
Had the car scanned for errors , some of which I knew about ( sort of ) . This is the result and
what I think I need to look at to fix them- highlighted in blue
BUT
I am more than happy to be corrected or offered alternate solutions to the errors shown.
A sense check please .. Thanks Andy.
I do not have VCDS at the moment so cannot scan again, this is all I have
to work on and any input from you guys so all comments welcome - other
than sell it - will never happen ..
A couple of points for starters
Its had a new battery
Its had new key fob battery
Had a new CCM P/S footwell and loom.
And I still have these issues..
Passenger door will not lock.
Roof not working- battery went flat, pulled battery out of car,charged it , put it back
roof stopped working ?
Checked wiring in door jams nothing broken.
PS Door control mod replaced - no change.
Now the scan ..
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8H0 910 560 HW: 8E0 907 560
Component: 4.2L V8/5V 0010
Coding: 0011714
Shop #: WSC 00000 000 08192
VCID: 65CAB1C6AF6C5E6970-513C
6 Faults Found:
17983 - Right Engine Mount Solenoid Valve (N145)
clean connection - delete fault code - if returns - new engine mount
P1575 - 001 - Short to Plus
18308 - Coolant Fan Control 2
check wiring or connectors to rad fans
P1900 - 004 - Open or Short to Ground - Intermittent
18010 - Power Supply Terminal 30
Battery has been disconectected - should go away in time
P1602 - 002 - Voltage too Low - Intermittent
16405 - Bank 2: Camshaft A (Intake)
underterminded fault - further invest needed
P0021 - 008 - ****** Setpoint not Reached (Over-Advanced) - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
Check coil packs and plugs 1st
P0300 - 008 - - Intermittent
16689 - Cylinder 5
P0305 - 008 - Misfire Detected - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04595
Shop #: WSC 00672
VCID: 3668268A124AE5F109-513C
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Check/Replace Steering Angle Sensor (G85)
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AB
Component: A4 Klimaautomat 1323
Coding: 00100
Shop #: WSC 00672
VCID: 61C2A5D6EB4432498C-513C
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 00000
VCID: 356A21860F4CEEE900-4B00
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 2015
Coding: 0010104
Shop #: WSC 00672 785 00200
VCID: 39722DB673540A89E4-513C
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01011
Shop #: WSC 00672
VCID: 438E4F5E51984059BE-4AE6
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 980 L
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 01401
Shop #: WSC 00444
VCID: 387428B2185E13811B-5120
WUAZZZ8H84K900251 AUZ6Z0C0463059
3 Faults Found:
01176 - Key
Unclear ?
07-10 - Signal too Low - Intermittent
00668 - Supply Voltage Terminal 30
Check Fuses wiring connection to control module
53-10 - Supply Voltage Too Low - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Check CCM again ... Check Fuses
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00000
VCID: 6FE6D3EE2D9094390A-513C
4 Faults Found:
01350 - Alarm via Theft Warning System; Rear
Check alarm in boot if needs replacing.
43-00 - Closed
01839 - Transceiver Module 1 for Interior Monitoring (G303)
52-10 - Supply Voltage Too High - Intermittent
01349 - Alarm via Theft Warning System; Front
43-00 - Closed
01838 - Transceiver Module 2 for Interior Monitoring (G305)
27-00 - Implausible Signal
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CQ
Component: Komfortgerát TBF 4336
Coding: 06798
Shop #: WSC 00089
VCID: 02008A5A0E028951F5-4B00
Subsystem 1 - Part No: 8H2959802
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8H2959801
Component: Tõrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0001
12 Faults Found:
Check CCM again Check Fuses
01134 - Alarm Horn (H12)
29-00 - Short to Ground
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
00955 - Key 1 ?
00956 - Key 2 ?
01331 - Door Control Module; Driver Side (J386)
Check CCM again. Check Fuses
01560 - Passenger Door
Check Central Locking Actuator . Check wiring/to and from.
58-00 - Can't Lock
01332 - Door Control Module; Passenger Side (J387)
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 040C8C4214168761C7-4B18
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 M
Component: concert II GRO 0001
Coding: 00203
Shop #: WSC 00672
VCID: 31621596FB24C2C95C-4B00
2 Faults Found:
00856 - Radio Antenna
Check Ariel lead cable kinked broken
29-10 - Short to Ground - Intermittent
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 A HW: 8P0 862 335 A
Component: FSE_255x BT H17 0030
Revision: 00000001 Serial number: 00000000039735
Coding: 0000502
VCID: 346C1C825436F7E137-5120
End-------------------------(Elapsed Time: 05:31)--------------------------
QuattroCalum
The best thing I can suggest is to clear all codes and see what comes back. Would be worth getting a lead and installing VCDS Lite, this is the free version but it will let you read error codes.
Regarding the misfires, I'd check all the pcv breather pipes, these split/break/leak due to the repeated heating and cooling cycles. Any leaks can and will cause lean codes and misfires.
Alarm horn batteries could need replaced, they are supposed to be a sealed unit but you can get into anything if you're determined enough, look on YouTube for a how to.
