RNSE update and Bluetooth
Pigeon
Devon
Hi all,:sign imnew:
I have a 2007 A4 with RNS-E showing the numbers in attachment.
1. I currently have genuine nav disks and am concerned updating to postcodes and cameras could potentially mess things up if buying a bad copy - i've read that you can't backtrack once a newer version is installed and that Audi never made such disks as well as the type of disk the info is burnt on. Also reading about codes and things get me wondering if it's worth it? I keep coming back to this even the the image doesn't show the correct postcode? https://www.satnavishop.co.uk/2016-...isc-speed-cameras--7-digit-postcode-134-p.asp
2. A well asked question but is there a good bluetooth option? I almost bought https://connects2.com/Product/ProductItem/CTAADBT004 but found out I'd loose the CD changer in the glovie. A local car stereo retailer put me off anything Dension. Other comments like potential bad quality through an aux jack kinda defeats the purpose of having a Bose?
Is there anything out there worth buying without needing to drop the exhaust and install 5 more cigarette lighters:shrug:
Something to work with the stearing wheel would be a bonus!
Thanks in advance.
Hi, I used the update from the Satnavishop and I have 7 digit post codes and it will update your SW as well, works well including the speed cameras.
Look like Audi are not adding 7 digit postcodes so i am sticking to this one.
thanks fella. i've seen a lot that look similar to that. do you know if you sacrifice the cd changer in glovebox?
i think i need to update the software too maybe
If you have aux plug in it replaces that. If not then u need it codi g but it won’t affect cd changer or phone connectivity.
